Tech Issue: Bontrager Wheel and Campi 10
I just got a Bontrager Aero Lite wheel set and are using it with a Colnago frame and Campi Record 10. I noticed that the rear derailleur’s cage at the upper pulley is slightly touching the spokes, using the 25 or 23 cog when climbing or out of the saddle. I adjusted the limit screws as much as possible. Never had this problem with my Kysiriums. Is it caused by the angle of the spokes? Any idea how to fix it? Thx.
Kyseriums are narrower wheels. The solution is to go to your shop, where they will hopefully have .5 or 1mm spacers to slide on the cassette body behind the cassette. The trick is that you have campy, and the very availible shimano spacers are too narrow (I.D.) to fit over a Campy hub body.
This is all assuming your derailer hager is alligned correctly. Have that done first
