Tarmac SL7 stem on Merida Scultura?
Does anyone know where I can get a stem cone spacer to fit my merida scultura to allow me to run a specialized sl7 stem? I want to switch the current set up of the FSA SMR stem to a tarmac sl7 (standard bars also going to roval rapide) but im struggling to find anywhere that sells or makes a transition piece to cover the headset bearing/frame that will allow me to use the sl7 spacers and stem.
There happens to be one the other way round, FSA spacer for sl7 frame but given that the spec parts are spec bikes, its proving dificult to find! I was thinking someone may have 3d printed a solution for this but cant seem to find!
thanks!
Here you go…
Ah, fantastic!! Although, pretty lengthy delivery to UK ! Thanks again
