I am looking for negative feedback on Biknd’s Helium V4.
The Helium seemingly offers the protection of a hard case and the convenience of a soft case. Limited, but sensible, disassembly of components such as the cockpit, seat post and derailleur is required. I like the integrated chassis, the protective nose cone and protective base. The air bladder is a creative solution to package everything together and protect the bike laterally. The bag looks “solid” once packed and seems to be the most protection possible in a soft case. I’ve found nothing but positive reviews.
This is where you come in. Please share bad experiences with Biknd in general and the Helium in particular. Skeptics and critics are welcome. Please tell me why I should avoid this bag.
I have the jetpack and have been very pleased with its durability and ease of use. I cannot remember why I Chose that over the helium. I’ve had mine a few years now. Maybe something different in v4 because I look at that and think I like it better…
Edit to add - I remember why i went jetpack over helium. I liked that both front and rear locked into the metal base frame. Rather than just the front on the helium.
I have second hand knowledge of zipper issues and the bladder losing/not holding air on some earlier/older versions of the case only after a few uses.
Again, early production models and do not know if this is still an issue or not.
Hello,
I’ve had a Jetpack for 4 or so years. At first, I’d arrive after a flight and the wheel protection would have deflated. However, in fairness to them, each time it happened they UPS’d over night a replacement.
Anyway, perhaps 2 years ago, they sent replacements that have been fault free - I believe it was the material and design of the protection that caused them to keep failing - the news ones have been perfect
the bike is light - carries a bunch of stuff, travels long haul half a dozen times a year, I have put my road / tri / enduro and gravel bikes in it and its great
Echoing what’s been said above, a friend had one on a demo shortly after they first came out. Bladders lost air over (a short) time. No experience of later models, or how easy it is to fit a replacement bladder.
Having worn a plastic boot with inflatable bladders when I broke my foot, I think I’d regard them (the bladders) as more like consumables. That said, one could say the same of the wheels on a hard case.
I’ve done probably half a dozen longhaul’s with connections with the new ones and no issues.
The issue - I think was a combination of the type of plastic and the valve. I think they were susceptible to pinch flats and the valves had no relief for over inflation
the new ones are great - very different
easy to replace in the jetpack, can not speak to helium
that said, the case is awesome, weighs nothing, easy to maneuver. its made of cordura, so I am beginning to see wear on corners but not sufficient to warrant doing anything about it, and its travelled perhaps a couple of dozen or more flights.
Tsa deflates the blatters to see the bike. Lots of trips, no problem keeping them inflated prior to travel, goes through tsa and never comes out pumped up. Bought a evoc, tired of wasting my time with this bag. Straps all broke, wheels broke, never atayed pumped up, Bad design for tsa.
I replied to you in the other thread, but I want to also mention that Biknd also made a special case for the new Cervelo P5X. From what I can see, it didn’t how specific to the P5X is, but I didn’t look very close either. I am not sure if you would need to disassemble the aerobar for that case.
I have the V3. Had some issues early on with the bladders deflating. Sent Biknd an email and got a reply back the next day. They sent me upgraded airbags for free right away with no hassle!
I have one. Several trips. Never deflated, despite the above comment. Seems to protect fairly well. I have no faith in baggage handlers, so this gives me at least a bit of relief.
Let me know if you have any questions in regards to our product. We have recently upgraded the Helium v4 to include new nylon airbags and plastic exterior sheeting to provide more protection plus many more features.
Hi! Thanks for chiming in. Honestly, I’m having trouble finding reasons not to buy this case. It appears very well designed.
Are you aware of any reoccurring problems with damaged bikes in the case? I know there are always the unavoidable outliers. I’m interested in reoccurring problems and how to avoid them. Slowtwitch is a good place to flush out those sorts of things, so the fact that nothing has come up yet is a good sign.
Can you address the deflated airbags referenced by a few other users in earlier posts? Is that an issue to manage?
Any concerns about fitting a size 58 Cervelo P3 into the case?
Of course no problem. Yes, we have had some issues with the airbags however we have always replaced them free of charge and are happy with the new technolgy that we are coming out in the Helium v4. The most important reason of why we produce these products is to protect your bike. Touching wood we have been very lucky with bike damage. If you remove the airbags in the old generations then the protection becomes the same as the other soft shell products on the market.
You will notice in the new Helium and Jetpack that we also now include plastic sheeting (that is cut so that the case can be folded down) in the outside layer with foam that adds even more protection.
The case is designed for the type of bikes that you mention.
Thanks for helping me identify this case in the other thread, and for sharing your experience. I am impressed with the design and found nothing but positive reviews.
I started this thread to flush out negative feedback and am encouraged by the absence of anything significant so far. I’m very close to buying this case!
I used an older version of the Helium and had no issues. When I decided to buy my own case I went with the Jetpack because it seemed like it would fit my mtb better.
As mentioned before the only issue I have had is with the bladders loosing some air. Even the one time I forgot to pump them up before leaving I had no issues, and I had my disc, a front, and a spare rear all packed in the bag.
The case is easy to use and light. Roomy enough to pack other things in it as well.
Airports that have big X-ray machines don’t need to open it up. Smaller ones will hand inspect it so keep small items contained in bags etc.
Devil’s advocate. Just moved across the country and got the Helium 4. Put two sets of wheels and a spare bike in the case and sent it with movers along with some accessories. Was on the moving truck from Nov 26th to Dec 7th and it showed up 1800mi later in fine condition, bike unscathed, and air bladders still perfectly inflated. Was able to pack it down after into its small storage bag and stick it in the corner of a closet. It’s built extremely well from what I have been able to tell getting my hands on it.
