Tacx Flow i-magic, can it send wattage over ANT+?
Hey.
I’ve just bought a (used) Planet X Stealth Pro TT bike, and I also got a Tacx Flow trainer in the deal. It comes with a head unit (which has one connection (RJ11/RJ45) to connect it with the roller), it seems to be a Tacx Flow Ergo Trainer, but it also says “i-magic” on the resistance bit, if that means anything to you. In the head unit I can see my speed, cadence, wattage etc. But ideally I would want this to be sent over ANT+ so I can use my Garmin watch to gather the info, so that I can pass it on to Training Peaks/Strava, but it doesn’t seem to be able to do this.
Is there any solution to this? Can I pick up another headunit? Anything else? Thanks!
Any ideas?
