I’m looking at spending a little money (about $200 - for a Force 22 crankset to interchange the arms with the Quarq) to switch my Quarq crank from 170mm crank arms to 165mm crank arms. For those of you who have made this change did you notice a difference? And was it a positive difference? I ask because it’s an experiment I want to test out in the “off season” - albeit a bit of an expensive “test”. It may or may not work for me. My goal is for faster TT speeds (TT races, not tri’s).
I don’t feel “tight” in the hip flexors, but I did raise my bars this season about 5mm and increased power output so I think my hip angle may be affecting my power output.
And will a 5mm crank arm difference be notable? Should I consider 162.5mm arms instead? I’m 6’ tall.
If I make the switch I’ll likely just raise the saddle 5mm and leave it at that for starters - lowering my position a bit and opening my hip angle. If needed I’ll raise the bars and maybe move saddle/bars back 5mm too.
I made the switch from 172.5 to 165mm 3 years ago and will never go back. Power should go up, lower back should be less fatigued if that is ever an issue, and it gives you a chance to be in a bit more aggressive position.
My biggest flexibility problem is tight hamstrings. So my limitation with going lower and reducing power may be more related to my tight hamstrings than hip flexors. It’s why this “experiment” may be for naught, but unless I try shorter cranks I just won’t know - so goes my thinking.
Michael
I swapped 170-165 this season. I thought at first the difference in comfort was noticeable. I have a pretty low position and I’m still miserable when riding at FTP. Miserable as in much more miserable than road bike. But maybe less miserable than riding 170’s?
My TT FTP is still roughly 30 watts less than my road bike. And I’ve ridden my TT bike a LOT this year. So I guess for me the jury is out. I think shorter might be more comfortable. I think it might help my knees stay away from my chest a bit better. I do like to ride very open so hoped 165’s would put out more power for me. Nope. I ride 172.5 on my road bike.
I’m doing an Ironman here in under 3 weeks and I’m actually considering swapping back to 170 after that just to see how it feels again. We’ll see.
Very interesting. Thanks for sharing. BTW - also ride 172.5mm arms on my road bike. My power is about 20 watts less on my road bike at FTP than on my TT bike. Like you, the difference may merely be an interesting experiment with no significant improvement. I swapped 170-165 this season. I thought at first the difference in comfort was noticeable. I have a pretty low position and I’m still miserable when riding at FTP. Miserable as in much more miserable than road bike. But maybe less miserable than riding 170’s?
I thought about doing it for a couple of years and just made the jump 3 weeks ago. Wish I had those couple of years back because it has helped me out a ton. Like you I have extremely tight hamstrings and my pedal stroke is now a lot smoother, maybe 5-7% more powerful, and a lot more comfortable in an aero position.
During the last 8 years I have never been able to stay aero longer than 7 mins and I was able to stay aero for 30 straight mins on the trainer during my second ride. I do realize than I am outlier with hamstring flexibility so most people will not see this dramatic of a difference but it was night and day for me after the second pedal stroke on the 165’s. I came from 172.5s. Hope you have a similar result if you give it a go. Cheers!
I’m not quite sure how shorter cranks have helped you mitigate tight hamstring issues. If you kept your position the same (assumption), how do shorter cranks help hamstring flexibility? I can see it affecting hip flexion, but not hamstring issues.
Just made the switch. Feels amazing. Never going back. Thinking that maybe I could even make use of 160mm. Had 172,5, and still do on road bike. Last years IM I had rash on my quads from bumping into my chest (spilled some sports drink on the legs so got slightly glued to my chest every revolution).This year I was much more comfy and also a little more powerful (but also fitter so yeah apples to apples).
Great questions. I always struggled to get over the top of my pedal stroke without my hips bouncing and had read several articles suggesting tight hamstrings cause this issue on the top of the stroke. Maybe its caused by tight hip flexors and not tight hamstrings. I took biomechanics in college 8 years ago but never got the opportunity to take a deep dive into the muscle activation from 10 o’clock to 2 o’clock of the pedal stroke so I don’t know for certain what causes the limitation.
You can raise your seatpost because of the 5mm you save on the bottom end of the stroke – the benefit I found was at the top end, where the hip angle really feels more open. A side benefit is less likelihood of a pedal strike, but that’s only for certain types of situations . . .
I went from 175mm to 165mm. The cadence change is noticeable. I have most of my base miles on 175mm so my legs get tired in a weird way on 165mm, but I’m still getting used to it.
I actually have 175mm on my trainer and 165mm on my tri bike.
Assuming power remains constant, then shorter crank arm means either same force at the pedal but higher angular velocity (to compensate for reduced distance to center of rotation), greater force applied at the pedal but same angular velocity, or combination of the two.
So shorter crank arm often results in higher angular velocity (which is just cadence multiplied by a constant).
My cadence also went up. I was averaging 75 rpm with 170 cranks and now I’m at 85 for easy spins and just over 90 for intense efforts with 165 cranks.
