No.
Think “neutral” your eyes should be straight down to slightly forward.
If you can see your feet, that means you are probably bent at the waist, your legs are dragging low, and you have extra drag from your head.
Yes. I’m sure you are spot-on about bending at the waist and dragging my feet. I’ll try to get rid of that waist bend starting tonight. Stopping the foot dragging and kicking for propulsion are gonna take awhile.
All else equal, I’d have thought that keeping my head as low as possible is best. But, now I did a little more thinking and realized that, resistance to motion in air is much less than resistance to motion in water, so why would I put more of me underwater. I’ve no instincts about hydrodynamics…
I like what you are saying about the proper form! I can do that. I’ll have someone videotape my form in a few days after making adjustments.
thanks!
Next time you are at the pool, go find a wall. Or maybe there’s a wall at your house. Use it as a guide.
stand with your back to the wall, heels pressed against the baseboard. raise your arms overhead in a streamline position, until the backs of your hands touch the wall, and albows are pressed right behind your ears. Your heels, butt, shoulders, and hands should all be touching the wall, and you are looking straight ahead.
That is your basic swimming posture, then you just add the pull, kick, rotation, and breathing from there. But you want to remember that basic posture. That’s what gets you horizontal in the water with a minimum effort. Not overkicking, not “pressing the T” or whatever that thng that TI espouses. learn what a straight body position feels like, then add the pull and a little bit of kick, and learn to breathe in a way that disrupts the streamline and pull cycle the least. It’s ultimately pretty simple (but not easy)…
Thanks for this post Jason. I’ve tried this wall set and when my heels, butt, shoulders are against the wall I can’t get my arms up over my head with my elbows pressed right behind my ears. I’m a MOP swimmer and do a lot of surfing. I’ve always had extreme tightness in my shoulder blade area. I’m starting to try and take some steps to ease this shoulder blade tension which I think will help with my swimming posture and basically my posture in general. Do you recommend any specific exercise, stretch or have any videos/articles that can guide me in a direction of solving my problem? I appreciate it.
