Swimmers ear?
I have been swimming regularly for a few years and never had any ear problems except for general water in the ear from time to time (think Kraemer jumping up and down on the plane)
Yesterday while doing my normal set, one arm drilling minding my own business I got an incredibly sharp pain in the right ear. So sharp and fast I stopped mid length and stood up in the pool and grabbed my ear. It was almost as if water went down into my ear canal.
It hurt all the rest of the day. This AM there is still a little dull pain.
Just hoping anyone with more experience than me could speculate:
a) what happend
b) how do I prevent it from happening again (cuz it hurts like hell)
c) how do I treat the existing problem and
d) if this persists for another 24 hours should I have it looked at and if so should I just go to local clinic and see Dr. X or to someone more specific
Thanks for any help
Try equal parts alcohol and white vinegar. Drop or pour in ear and let it stay for a few minutes. Turn head and it should come right out. I had a pretty bad ear infection one year and this treated it quickly and successfully.
thanks russ
bump
The alcohol/vinegar is an old scuba diving trick from way back. However, if it doesn’t do the job then see the family physician for anti-biotic ear drops. I’ve had to do this a couple of times for scuba ear infections that didn’t respond to alcohol/vinegar.
thank you
You can also buy some over the counter non prescription drops for swimmer’s ear, either at the pharmacy or at a local scuba shop. But again, if it’s really bad you’ll need to get the “high test” prescription stuff.
Swimmers ear sometimes hurts like that - like a knife shooting down your ear canal, and going further than you thought possible. Just shake the water out of your ear, and wait it out, the sharp pain will clear and usually won’t come back for the duration of the swim. When it gets bad, it’ll hurt/throb all the time. Either way, the white vineger/alcohol should clear it right up.
I dealt with a horrible case of this leading up to IMLP last year. Antibiotics were the only thing that worked for me. Get well soon!
** But again, if it’s really bad you’ll need to get the “high test” prescription stuff. **
Cipro drops. Best stuff to ever come out of a dropper.
I have used straight alcohol at times too. I used to have a lot of swimmers ear problems when I was a kid. Now, I swim with earplugs to prevent it. it sucks, but its better than a trip to the dr. if the pain doesn’t go away in a couple days then you better see the doc. middle and inner ear infections can mess you up more permanently than you might think. it can effect your balance which will do more than make you miss a couple swims. take care of it quick.
Thanks to all for your advice. Yes it hurt just like a knife and really shook me up as I have had no problems before this.
One last potentially dumb question. As I am treating it can I continue with my swim sessions? Normally I would just can them for a few days until I was sure it’s better but I am working with a swim coach twice a month for hourly sessions and my next session is tomorrow. Will my head fall off if I swim another hour with this problem. Thanks
Well, just from personal experience, I never had any problems swimming while treating swimmers ear. Most college/HS swimmers pretty much always have some level of swimmers ear. I only had it badly once - one ear canal almost closed up, both ears throbbed constantly, and I was cleaning green stuff out of them. But I was 15, it was the first time I got it, I didn’t know what it was, so I let it go on way to long. what did I do for it? … alcohol and viniger drops (and I think earplugs for a couple days that time). Definately did not stop swimming (4+ hours a day at point). Probably should have seen a doctor that time though : )
Usually when you get the knifing pain, just roar for a while underwater while holding the afflicted side of your head (Well, that is what I used to do anyway ;), then shake the water out… once the initial pain drops, the pain should be much less the rest of practice (this would often happen to me 10-15 minutes into of a 2+ hour practice). When you finish the practice, shake/dry your ears really well (do this everytime you swim… duh), and then put the drops in. If you put drops in pretty regularly (2-3 times a week for me, swimming six days a week) even when you arn’t feeling any pain, you can avoid the problem completely. Of course, you’ll smell like vineger, which can cause other problems. The store bought stuff doesn’t smell as bad, but costs a lot more and isn’t quite as effective (or… maybe it doesn’t seem as effective because it doesn’t smell strongly…).
If it doesn’t improve w/treatment, see a doctor like these other posters are saying. I definately am not a doctor, and I really have no idea why the sharp pain happens like that sometimes, while at other times, swimmers ear is a constant/throbbing pain. You should be pain free in just a couple days of treatment, while continuing swimming.
great reply thanks a lot for your help
I used to get that swimmers ear occasionally. Am i the only one who uses those wax type earplug things? Slide on my cap and i never get water in my ears now…
If all those homestyle remedies(alcohol,vinegar,etc…)does not work and you still have a problem definitely go see and ear specialist.
Same thing happened to me couple weeks ago and I waited one day too long and ended up with an infection.
To make a long story short I could not swim for a week because of the time release powder antibiotic in my ear canal.
Do not wait more than 48 hours.
I’ve had swimmer’s ear a bunch of times but it never hurt while swimming. It would always hurt that evening or night and would always get better within a couple hours of pouring rubbing alcohol or hydrogen peroxide in my ear. The vinegar/alcohol is the standard swimmer’s remedy. We’d often pour rubbing alcohol in after every work-out. I’ve heard there is some concern with the alcohol causing too much drying of the tympanic membrane although we all did it lots of times…
Swimmer’s ear is technically an outer ear infection or otitis externa (not an inner or middle unless you had a hole in your ear drum…). Its from chronic wetness and overgrowth of bacteria that leads to a skin infection in the ear canal. If it gets really bad - your whole canal swells shut and it REALLY hurts. Most early mild infections/swimmers ears gets better with almost anything. Although they can settle down on their own then really falre back up in a day or 2 so I’d do something for a few days.
Prevention - keep canal dry or put in drying agent/antibacterial agent after swims…
Persists - a basic clinic should be able to deal with a simple outer ear infection or we’re all in trouble. Standard tx is too keep the ear dry until better but we’d all swim through them (with alcohol) as kids…
According to the Sanford Guide to Antimicrobial Therapy 2005:
“Recurrences prevented by drying with alcohol drops (1/3 white vinegar, 2/3 rubbing alcohol) after swimming then antibiotic drops or 2% acetuc acid solution.” We’d just use the alcohol drops to treat and prevent - I never needed antibiotics.
Dave
I’ve also had swimmers ear 1/2 a million times (competitive swimmer thru college). If you’re feeling the knifing pain for more than 24 hours (more than one or two practices) get ye to the dr right away. The one time I waited more than 2 days, I ended up have a nasty ear/swimmers ear infection (caused from bacteria-laden water being trapped for too long in my ear) - that lasted 2 weeks (with no swimming) and had to take some really gnarly swimmers ear drops 3 times per day. Straight up swimmers ear can be basically cured with some ibuprofen (it only hurts on the outside ear part, not inside the ear) - and some gentle “getting the water out” after practice, but anything deeper than “the outer ear canal” can be serious and you should treat it as such. just my .02.
