My goal here is to get at least 3 possibly 4 days in the pool. My plan is to, maybe incorrectly, base my workouts on a schedule similar to running, with a Long, Speed and tempo type workout. I want to keep things simple because It’s easier for me to acomplish “X” number of “Y” then it is 400 different things in one session.
My “Speed” day’s I typically do 50’s and 100’s. Tempo day is 100’s and 200’s adn LSD day 400’s & 500’s. My problem comes in when trying to figure out how hard and how much recovery I should be taking.
So what are some standard recovery times and efforts for some standard distances in the pool? Does the recovery time go up as the effort goes up? Or should you be doing repeats at an effort that you need “x” amount of recovery?
For example, no laughing I’m a crappy swimmer, I can do an All out 50yd in around 35-40 seconds. But after that effort I would need significant recovery, say 30-40 seconds to be able to even attempt to get close to that again. OTOH If I do one at time of 50’ish I can do several, 5-10, on a minute. Although I’ve not done many all out attempts at 100’s, 200’s etc the same trend seems to appear throughout the distances, which makes sense.
The other question is how should the efforts compare to each other? Obviously I can’t hold the same effort for teh 500’s as the 50’s, but should the effort be such that the RI is the same or shoudl the RI be a percentage of the total time of the interval?
If the above questions make any sense whatso ever any help would be appreciated.
~Matt
