I have been out of triathlons for 3 years and need to get back in shape for next summer. Lycra and spandex is not an option for me (out of courtesy for others) as they are too tight and downright inappropriate for my size. Board shorts are just too long and restrict movement. Any suggestions would be much appreciated.
Well, if not board shorts and not Lycra/spandex => polyester jammers!!! They will last forever! I mean, if you’re going to wear cycling shorts in public, that’s practically the same thing (without the pad).
Probably not the response you were looking for, but if you don’t want to wear elastic trunks, and you don’t want to wear loose trunks, then that kind of only leaves nudity?
you could try swimming in the running shorts that have a compression-type liner and then somewhat looser shorts over. I don’t think this would be an improvement on board shorts, though.
I wouldn’t worry about what others think. I’m certainly a larger swimmer right now, but I still wear jammers. And thank God we don’t still wear those little speedos we use to wear 20 years ago.
Holy crap! I just checked, and you’re right! They’ve been around since 1961 and make outstanding surf trunks! I own 4 pair and they last forever! Hope they can restructure and make trunks once again.
Dont worry about other swimmers, we all accept that 99% of us don’t look great in speedo’s so swallow your pride and wear what you want. I’m 20kg overweight and if I hadn’t been given a pair of jammers to try, I’d still be in “budgie smugglers” to this day.
