Please tell me someone is already working on this. I MUST know which is the queen of aero. Are there any other brands expecting to launch a new gen tri bike?
i vote this thread of the year.
This would be awesome. I would definitely throw in the Cube Aerium as well, supposedly one of the fastest in the wind tunnel.
I vote this clickbait of the year…
You obviously have no idea what a HUGMONGOUS PIA this would be.
Yet, since I’m one of the <3 people in the world who’s actually successfully designed then done this exact thing, you get the bikes, wrenching help, a super stable & consistent rider for the tunnel + the funding I have the know how and the wind tunnel time.
I think I can actually make it better & more accurate than the first, only & last time this was done.
And the last time was one of the smallest margins of error ever published for wind tunnel testing in the bike industry. Yet I’m pretty sure I know how to make it another 2-5% more accurate.
Estimated cost would be about $7-9k before bikes.
You get the bikes & funding and, well, this sums it up
Most manufacturers probably do some level of this with iterations of their bikes.
Lest we forget, all hail JackMott for this assembly of data http://www.aeroweenie.com/data.html
Given the exorbitant cost of these bikes, anyone considering a major purchase in the next couple years should find value in such a study. I’d happily chip into a gofundme for a bonafide independent study.
Would like to see how the old Speed Concept stacks up.
Why bother? They are probably all within such a small margin of error that a creased sock or twisted helmet strap would negate any advantage.
Buy some shoe covers instead.
I think a PR6/5 needs to be in the mix too! (simply because that’s what I have and id like to see how they stack up )
Add the Kú TF1 as that beat the P5dusc already
Jeroen
I’d be down to throw some money at this, thoughts Brian?
True, not with a rider on though. Our protocol was more stringent than anything anyone had done to that point, which enabled us to set the standard in low standard error.
I’ve always thought someone should retrofit a box truck to have a scoop on it to force wind through the box and out the back. Then put your rotating yaw bike jig mounted into the box truck. You know the ones like a Uhaul with “gradma’s attic” above the driver’s cabin? Just cut that sucker open to the wind outside and open up the rear door.
Instead of a multimillion wind tunnel, just drive around the interstate with the cruise control on. Maybe some baffles or something to direct the air and volume.
That’s my idiotic idea for the day.
Actually there used to be a dude who had something like this set up in a box truck.
ok everyone
I’ve gotten some whatsapps’ and emails regarding doing this type of aerobike shoot out. If the demand is there, we can get the bikes, set everything up etc I think we can do this.
I have some ideas on how to make it more applicable to more people vs the last shoot out and also tighten up the standard error a bit.
I’m not taking the lead on sorting everything out. I am willing to take the lead on putting people in touch with each other to get this ball rolling. If you’re serious about this, realizing in addition to the bikes we’d need to raise somewhere between $6-9k contact me. I’ll start some sort of meet up and we can get this ball rolling.
Yes, this. It was already proven that these super bikes are all so close that any differences will likely be due to the shape of a particular rider, what kind of hydration they use, which wheels work better, etc etc.
I’m all for seeing interesting data, but I’d rather see an updated and proper testing of all the most popular aero wheels and tire widths (including a HED3+ clincher trispoke please!).
I’m surprised nobody has mentioned, given the peak aero sameness of all bikes, the things that make the bikes different and potentially better than others.
Judging from some data from 2017 (thank you desertdude) Im guessing aero wise you could throw a blanket over all of them.
Even my lowly FELT B series held its own among those with greater pedigree.
Yeah, buy the one that looks the best to you, or has some feature you want. Any aero test is likely to be specific to whoever is used as the test rider (or test dummy).
What about the OG disc brake TT, Parlee TTiR? ;
