Hey guys, I recently got a sump pump installed by a plumbing company. The problem is we used tethered float switches and now they are constantly getting stuck on the side walls of the sump pit, because of this my basement starts flooding and I have to remove all the water as well. Do you guys know how to fix this problem? If the repair is simple then I can do it on my own. Any help on this would be great.
I’m a veteran of a long, multi-year running battle with the two sump pumps in our basement. I can’t offer any help because I’m not sure what a tethered float switch is and even more disheartening, in my experience, when you get that problem fixed another one will likely crop up within a few months
Maybe try something like this…
https://www.plumbingsupply.com/sumpwatcher.html
“If” I get a chance today, I’ll call my pump supplier and see what they would suggest. Also what’s on the sump walls to cause the float switch to stick?
I’m confused. If its tethered it goes in a prescribed arch. No? Why would the plumbing company install it where the arch intersects with the wall? Ifso it doesn’t sound like they know how to install sump pumps. I had an untethered float and it would get caught on the wall so I solved the problem by tying the hose to the top of the submerged pump such that it couldn’t reach the wall. I also have a backup pump that runs off my water line (pressure driven) so if my main pump doesn’t work or electricity goes out I am covered. It’s float goes up and down on a slide so it cannot get caught on stuff or interfere with other pumpl
Get a vertical float switch. You can google them as needed. Basically they move inside a vertical cylinder, or on a vertical rod.
Try a Little Giant next time. Most of their pumps have an internal pressure switch that cannot be interfered with. Awesome pumps.
The one I had, the cord to the float passed through a clamp. I loosened the clamp and adjusted the position of the cord so that the float didn’t touch the sump wall and still had enough slack to be able to rotate enough in both directions to activate and deactivate the switch inside.
This is what I would recommend. I had the exact same problem and fixed it this way. Annoying as hell to go down to the basement and have a couple inches of water. At least it is clean water and not sewage (at least in my case).
Thanks a lot guys
