Sub 5 Hr Bike Split on < 200 watts
Thoughts?
Possible. it depends how small you are.
There is actually a guy on here who did that at Austria. He posted a race report from Kona as well showing his frontal and it ain’t much…tiny. I remember looking at that and thinking ‘wtf?’. He has a sick position!
I rode 5:04 at IMC a few years ago with an average of 178 watts (this includes coasting) I weighted about 145ibs.
Bike was very cheap alum frame with mavic cosmic carbones, not too aggressive position.
But how tall are you?
could be close, depending on course.
I did IMFL last month in 4.57.01 at 208w (217 NP), and I weigh in at 156 lbs with full aero gear, disc.
5’10
Thoughts?
My thoughts are that there must be at least one of the following going on to achieve sub 5
Very aero Very small person miscalibration easy course great pavement no wind drafting
Or all of the above.
For example, if Paula Newby Fraser or Natasha Badmann had a powermeter, I am sure we’d see numbers lower than 200W.
For the 145 guy doing almost 5 hours at IMC on 178, saying his position is not too aggressive (given ~3000 feet of vertical at IMC), I think other factors are at play (maybe some miscalibration). That’s a 3255 Kjoule ride. Keep in mind it takes around 600 Kjoules just to lift a rider plus bike vertically up all the climbing on the IMC course. So that leaves around 2600 Kjoules for this rider to do a pancake flat 5 hour course…that would translate to 144 watts on a pancake flat course for a 5 hour ride. Is this remotely in the realm of possiblity for a 145 lb rider with a not so aggressive position? I got my bullshit meter out on that one.
Please fess up to miscalibration.
Dev
Edit: corrected for 178W
If the start and finish are at the same elevation, he’ll get those 600 KJoules back.
Depending on RR, pancake flat course would put him at .22 - .24 for Cda. I don’t know if that is bullshit, my frame of reference is much bigger ;-).
I did 2:30.xx at Timberman … didn’t race with my powertap but it is impossible that I went significantly over 200 and likely that I was below 190 (2x20 power only 230-ish) I’m small though, 5’4 and 122-ish.
Should also add that I started in the second-last wave and am not a good swimmer so no doubt benefitted from slingshotting past a lot of cyclists as I was one of the last people on the road.
Miscalibration echoes my thoughts. I don’t know how but I’ve always thought my powertap reads low (despite “proper” calibration before every ride) based on peers’ wattage #'s on rides. Either that or I’m slippery as an eel…
For the 145 guy doing almost 5 hours at IMC on 175, saying his position is not too aggressive (given ~3000 feet of vertical at IMC), I think other factors are at play (maybe some miscalibration). That’s a 3200 Kjoule ride. Keep in mind it takes around 600 Kjoules just to lift a rider plus bike vertically up all the climbing on the IMC course. So that leaves around 2600 Kjoules for this rider to do a pancake flat 5 hour course…that would translate to 144 watts on a pancake flat course for a 5 hour ride. Is this remotely in the realm of possiblity for a 145 lb rider with a not so aggressive position? I got my bullshit meter out on that one.
Sorry just new at this - when you say is a 3200 Kj course, how do you go to calories expended? A converter puts it at 764,489 cals so obviosly it’s not that simple?
he isn’t speaking to the amount of energy your body would burn, but to the energy put into the pedals.
you would burn a lot more calories than you would put to the pedals.
Talking out of your ass as usual.
178W*(5+4/60)+3600 = 3255Kjoules (the 4/60 = 2/30 = 1/15 = 0.06666 is to account for the :04 in his 5:04 split).
To the poster who said, “you get all those stored joules back”, you’re right, you get some of them back, just not all, so my implied calculation for a sub 150W ride for a 5 hour ride is off. Climbing Richter and Yellow lakes you’re going at 15-20kph and coming down you’re ripping at 60-80 kph. There’s a shitload of your stored potential energy joules blowing up in the wind…maybe not all of them, but most of them.
Even if we say that his “equivalent flat course” wattage is sub 165 for a 5:04 ride, would you buy it? He said he is 5’10" and 145 and not too aero.
Classic
To add to the post, it also depends how big the guy is you are riding 7 meters behind and how fast he is going.
Here. Norm power of 185w at Austria for a 4:58 split. I raced Austria really light at around 132lbs (height 5’9). Pic below is from Kona this year, with an identical position to Austria.
http://i51.tinypic.com/29qgwox.jpg
Kona was norm power 192w for a 5:05 split, but I was heavier at ~136lbs.
Keep in mind that 1 Calorie with an upper case C is 1000 calories with a lower case c. To add to the confusion, people often write “calorie” when then in fact mean “Calorie” or “kilo calorie.” So 3200 Kj is 764 Cal, or 764,489 cal. However you obviously “burn” more calories that that, because your body not 100% efficient. As a rule of thumb, you burn about 1 Calorie to produce 1 Kj of work. So you would burn about 3200 Calories to produce 3200 Kj of work.
Dude that kills me to read ‘I was heavier at 136’. How tall are you? I think I went through 136 around the 6th grade!
OK, here is what i remember
I think that was 2005 which was a fast year for IMC.
Aero helmet.
I had 2 flats which shouldn’t effect things as SRM stopped recording, ride time was 5:04:xx
I rode conservative on the uphills and tucked like crazy on the downhills and from what I remember I was able to get at least 60% up the rollers in the tuck position without pedaling.
I was quite aero but not crazy aero like some, I can stay in that position for quite a long time.
It was an SRM Pro, could it have been off poss but not by much, on the flats my normal power was in the 190’s.
The number was well under 200, normalized power may have been low 190’s.
I have not raced for 4 years due to children, but now thinking I should come back to kick your skinny ass.
