Stryd (running) power meter
I want one!!!
Any coupon codes out there or deals!!
I need SOMETHING to make me pull the trigger!
They are stupid expensive. That being said, I got one as a gift and LOVE it (mostly for the real-time pace…the power is a “nice to have”). Never would have bought it on my own at $200 though (guess that what gifts are for).
If they could get the price in the $129-$149 range I bet they’d sell a lot more of them.
Damn you! You’re supposed to make me BUY one!!! Lol.
They don’t usually have any deals. I’ve only seen a black Friday discount.
I only ever saw a deal when they introduced the latest version.
That said, I love mine and would buy it again if my dog ate it. Like above, the real-time pace is fantastic. And, the power is very good at understanding real-time effort and effort between intervals and runs-- a million times better than HR or RPE.
I want one!!!
If you’re bad at pacing and live in a hilly area, it’s probably valuable.
How are they stupid expensive? Thats less than any bike powermeter out there and they have no competition.
love mine, worth every penny.
coupon for 20 off around black Friday. once a year only if I recall.
It’s probably one of the best investments I’ve made for running. We’ve lived at our house now for 5 years and I have never felt I could run consistently here. It’s super hilly at 6200ft. It took one run to realize how much I push the hills especially the small ones. That I was basically doing intervals every time I ran. It’s made a huge difference in how I run now outside.
Something that I’ve never understood about these…
Why does there seem to be no mention of it being one-sided…as opposed to all the discussion about one-sided bike powermeters.
It’s just a series of accelerometers and algorithms, not strain gauges, so unlikely to be much real discrepancy between left and right running.
Had one, lost it in undergrowth, wouldn’t buy another one. Only real pro I found was it taught me how significantly slower I needed to go up hill to not spike the power, but certainly didn’t revolutionise my training like bike power.
I may be completely wrong with this but i believe its because of what stryd is doing. When you look at a one sided powermeter for cycling the problem is that it only has the strain gauge on one side so it is literally taking the power on that side and doubling it to get the number it gives you as your power.
Stryd is giving you a calculated number based on a whole bunch of factors. So its giving you a made up calculated number from measurements it pulled, not a strain guage measured number. Now that number is remarkably consistent. I can run on the treadmill and you can see the avg power increase at each .1 mph speed increase so I trust the data within itself but its still a made up number. Essentially that is one of the main reasons I took a long time to get one.
My guess is if they used a dual pod solution it would be more accurate, but at what cost? Runners maybe more so now with shoe prices aren’t cyclists spending 4 or 5 hundred dollars for a dual footpod solution is probably not going to get very far. Realistically that is why run scribe moved away from the consumer market because they needed to charge more to be profitable.
I may try runscribe out too. Ive had two knee surgeries and it’d be interesting to see the data between legs. However, at the end of the day Stryd is consistent enough to be useful with only one pod.
Also, its still very early in the power game for running. For those of us who were around 15-20 years ago when power for cycling was just starting to get popular. It was first a mess because systems couldn’t recalibrate themselves easy. If you changed chainrings you basically had to do a full recalibration with weights hanging off your pedal and an excel spreadsheet to give you the calculation to input into the SRM. It was also insanely expensively a new DA SRM was over $3k. But that market has matured and its remarkable what you can get now for less than a 1/3 the price 15 years ago. I’m sure in 15 years the market for this will be mature with better more accurate data.
If memory serves, they are using accelerometer data to computer the run power. You’re right it’s fed through an algorithm (so is your bike power from your strain gauge based PM by the way with any platform you use, which is why your power numbers for the same activity might differ between Strava and Garmin Connect), but it’s consistent and seems to make sense. Just like with a bike PM, what’s less important is that it’s right, what’s more important is that it’s consistent, so that you can use the data to improve your training (or for pacing races).
Because the numbers are motion driven, rather than torque driven, I’m not sure that going dual sided would give you any better data, which is why they’ve likely strayed from that approach (although if sales dwindle, an easy way to snooker people into shelling out for something new would be to market a dual sided running PM…).
Many years ago, Stryd used to do a 2 for 1 deal around Black Friday, but more recently those tend to be smaller percent discounts. If you like metrics, and you want something that will give you a more consistent sense of how hard you’re working across different terrains and elevation, it’s worth it, even at full price. Mines several years old, and still works well (They did replace it for me once, because my very first one broke after a few months where the clip fits into the unit itself (I do mIx up a shoe rotation, so am constantly moving it between shoes), but the replacement unit has been problem free for a number of years now, I’m also more careful about how I put it on…). Just stay on top of the firmware updates and remember to charge it one in a while.
Likely the reason why Stryd’s business isn’t moving is that the device serves the run power purpose, and maybe doubles as a footpod for those who want to Zwift, but other manufacturers have started to offer power based on watch-based accelerometers (Polar), or chest strap HRMs that also serve other purchases, so it’s less of an investment for a singular purpose… And other than the carbon shoe arms race, the running world tends to shift slowly, so it will take some time for the concept of running with power to reach cycling levels of fanaticism.
I’ve had mine for 3.5 years. I don’t consider that to be very early.
I ended up getting a used one for like $60 when the wind one came out so maybe try eBay? Not sure if I’m missing much without the wind sensor but really do like it. Now need to actually follow a plan and see how it goes rather than my random “run when I can and go fast when I can plan”!
SRM has been around since 1988. So yes compared to the development time that bike powermeters have had to improve and become refined, this is remarkably early in a product lifecycle.
If it weren’t now, you could get discounts at bigger racing expos.
Good luck :smiley:
I respectfully disagree with the idea that it’s remarkably early. That indicates it came out very recently and 3.5 years is not very recent.
Mine is second generation and there’s a version after mine already. The first generation was 2015, so about 6 years ago.
However, I would say the the development has not had much progress in the last 3 to 6 years and there is a lot to be done.
Because the numbers are motion driven, rather than torque driven, I’m not sure that going dual sided would give you any better data…
I think this is actually a counterpoint. In cycling the kinematics are fixed so we know that no matter what happens, pedals are exactly 180 degrees away from left to right.
In running, one could have stride length differences, and other kinematic asymmetries at hips, knee, and ankle joints. If the leg with a Stryd sensor is left “dead” and one hops with the other leg, what would it report? There’s assumed symmetry and the errors are likely to be more severe than single-sided cycling power meter measurements since there are more degrees of freedom to go wrong.
Garmin’s running power is based on torso measurements, which may be considered a single degree of freedom if it only has a single ~vertical accelerometer, and it would have to make assumptions about what the legs are doing based on this measurement.
A single-footpod accelerometer gives some data to reduce the assumptions but the other leg must still be modeled, and I assume Stryd must still require some form of accelerometer on the torso by communicating with wrist accelerometer and more assumptions, or completely models torso movement as well.
I hadn’t looked into Runscribe until today, but it’s impressive, and represents the minimal amount of sensing required to avoid assumptions between hips and feet if using their two footpods + hip sensor.
That said, I find even Garmin’s data useful and have improved my running form based on its output, and I’m sure Stryd’s is similar or better. I think I would skip Stryd and stay with essentially free Garmin running power unless I’m willing to pay for runscribe’s 3-pc kit at $600, which is not bad compared to cycling power meters.
Wait … how are you getting power (running) with Garmin?
What equip. do you need?
