Diagnosed with a ‘Healing grade 1 stress fracture’ in the posterior left medial tibia…
Typical healing time for this? Should I wear a walking air boot for this? Physio doesn’t seem sure if its necessary…but if it’ll actualy help, I’d wear it…
Thx
Thx
That sucks. My experience was 3 months to heal, doctor did not think boot was necessary. Good luck with recovery.
How did you return to running after the 3 months, as in, speed and distance?
Thx
Seems like the same thing I had this time last year. I was told 10-12 weeks to fully heal but I started running after 8 weeks, very easy pace and it never bothered me again.
i’ve had 6 in the right post-tib. never used a walking boot. healing time is approx. 8-12 weeks, then ease back in with short easy jogs. (ie. start at 5 min and go up SLOWLY from there).
Have been there and done that as well. It does suck.
Advice:
I’ve had multiple stress fractures in my tibia. They can vary in recovery time depending on the severity and other factors (mainly lifestyle and how much you rest during the injury period). Generally all require atleast 6-8 weeks to heal. You can bike/swim/etc as long as there is no pain during activity (or after the activity). Wear a boot if you feel pain while walking. If you don’t you’re fine to move around without it.
When you start running again jog super slowly and easy (i.e. atleast 1.5-2 min slower than normal). Stop is there is any pain or soreness during the run or post run. Some doctors will have you start with walk/run intervals and some will do 20 min continuous every other day and build from there. I’ve done both and didn’t see a huge difference. The run/walk method likely leads to fewer other flareups while you’re building up.
I’ve been through this a few times so let me know if you have additional questions on specifics!
Thanks for the info.
So given that you’ve had them many times, was there anything you tried specific to prevent future occurrences?
I guess I’m trying to figure out if it was simply overuse, or if it is an indicator that I need orthotics, etc…
I know this is directed at TMR, but I can give my feedback as well.
You will get a variety of opinions, to be honest orthotics seem to be dished out all the time for reasons that do not seem entirely clear to me (ie it looks like a bit of money making for many sports practices etc).
My coach is very clear on this, it all comes down to load management along with potentially some biomechanical issues that a good running specific strength and conditioning coach can help out with.
Shoe choice is important in the overall scheme of things as well, my coach makes me train the longer stuff in more heavily cushioned shoes (which I know can be controversial) and save my lighter weight shoes for tempo/speed work and race day.
From what you have described, this sounded like shin splints (MTSS), just the worst end of the MTSS spectrum but the best in terms of stress fracture grades?
There is some low quality evidence that ultrasound may speed up the recovery period (did not work for me), but speaking from experience, it is important to wait out the recovery period before you load it up again and just start off slowly. I have run my fastest half marathons late this year after having close to 12 weeks off running with MTSS in July.
Thanks. I think I am of the same thought regarding orthotics.
I definitely have some biomechanical issues and imbalances, mostly in the hips along with CAM/FAI. So while I’m not a big believer in orthotics, I sometimes wonder if I’m making a mistake by not using them…ie. did my pronation cause the fracture, and would orthotics have prevented it…probably not, but who knows. I do have an expensive set of custom made orthotics, but they felt very…clunky and heavy…then they started squeaking in my shoes, that was the last straw…lol.
I’ve been running in New Balance Beacons for the past 3-4 months, using the stock insole with a metatarsal pad stuck on to it (partly for some big toe joint pain).
In general, over the past several years, it seems like any time I try to increase my run mileage over 30-40km per week, something starts to hurt…
I ditched my prescribed orthotics very quickly! Too clunky and felt horrible to run in. That was about $700 down the drain pretty quickly.
The root of the issue can be different for everyone and depends on your own unique situation in terms of athletic history, lifestyle, training, biomechanics, etc. Narrowing down a cause may be simple (ex: caloric deficiency or building up mileage too quickly) or may be more complex. I’d suggest discussing the issue with your coach, doctor or PT.
I am still working on tracking down my root cause but its likely training issues and biomechanic problems related to my unique anatomy (I have much smaller calves than quads).
Unsolicited advice. I had this and 8-12 about right but in the meantime you can:
Aqua jog w/ music.
Alter G treadmill w/ music; perfect to transition adding weight.
Crosstrain a ton.
Get things done like equipment responsibilites, get family things done etc.
GOOD LUCK!!!
look back at your training regime, 75% of the time these come from training errors,
There is a strong correlation with runners who stomp the ground on impact vs those who run lighter. The rate of loading with stompers is much higher and can lead to a stress response or stress fracture.
give this a read. https://www.jospt.org/doi/10.2519/jospt.2014.5334
Alter G treadmill …
That looks very cool! But I am probably 2000km from the closest one…
Thanks, will give that a read!
