Here is the deal, I can swim, bike, and run individually, at all heart rates for varying times with no “stitch” (a pain along my rib cage). But occasionally I will get a killer stitch during the run portion of my brick, even though there was no indication of one during my ride. Anyone else experience something like this? Any suggestions on how to resolve?
Thanks
Scott Jones
Issaquah, WA
Aaaah…finally an area I have some profound advice in.
As some previous posters of how stitches ( spasms of the diaphragm ) occur , I agree entirely. I had 2 or 3 races where I was powering along and then reduced to a slow walk, due to the inability to expand my ribcage. I was petrified that it would sabotage my first trip there.
As far as remedies of slow breathing , stretching arms , breathing deep ( IF POSSIBLE ) NONE of those worked for me , what did work was changing my breathing pattern.
Firstly , on your next run …take note of the following: When you inhale what foot is striking ? Continue running , five minutes later repeat.
APPARENTLY 85% of runners inhale / exhale upon right foot strike.I always got my stitch on the RIGHT side. I noticed I was doing the same. Like you ,I was only getting this on the run portion of my tri’s and had Kona approaching rapidly. It normally occurrred after 5 km’s intro the run.
TO ELIMINATE , TRY THIS:
Have your hard bike ride , then go strong into your brick and then wait for that little bastard to come along , just when you fell the hint of it…
Conciously try this , as your LEFT foot strikes ,inhale and then exhale , as per normal . It may require a sort of skipped breath to get going , but I have found it to be 100% successsful. It’s that easy.
Let me kow how this works out and if so , please pass it along. Good luck!
