Stem Stack Calculator
Is there a calculator that will give me the stack adjustment for various stem angles and lengths? For example, if I ride -6 degree, 120mm stem with a 73.5 degree HT angle, how much stack is that adding? Basically looking at how many spacers (or different stem angle) I would have to use for various frames in order to achieve my optimal fit.
Thanks
Get your trigonometry books out! :wink:
Found it!
http://www.brightspoke.com/t/bike-stem-calculator.html
or you could use the one here!
Right under my nose! What a resource ST is. Thanks.
Dan that’s awesome. It would be double awesome with a scan of a simple hand sketch of a stem, illustrating what all the input and output dimensions refer to.
good idea. we actually have a couple of versions of that. the other one’s here, and it gets from you HX/HY to stack/reach. that probably needs a sketch as well.
was always a big fan of this one:
http://alex.phred.org/stemchart/Default.aspx
My favorite, as it draws nice graphics so you don’t have to hurt your head as much to visualize the change:
http://yojimg.net/bike/web_tools/stem.php
http://yojimg.net/bike/web_tools/stem.php]
^that’s my favorite too!
i don’t know how long you’ve been back (i’ve been pouting and not logging on b/c i’ve been sick) but welcome back!
