I seem to remember reading on this site somewhere that stainless steel chains were more likely to break since stainless steel is more rigid/less flexible than nickel chains. Stainless steel chains are more expensive. Obviously they resist rust better, but I have never had a problem with chain rust.
What is this, a lesson in home economics? Stainless steel chains are more expensive, and you have no need of the benefit they’re supposed to offer. Hmmmm . . . what to do, what to do?
I have used the PC-99 and other SRAM chains with very good results. I don’t have a problem with rust because I clean my bikes after riding, and ride often enough that I go through 2-3 chains per year on each bike(road and mtb).
I’ve only ever had one chain break, and it was because it was well past needing replacement. Even so, the link came apart at the rivet, so I am not sure that was a function of material or manufacturing process.
