First off, this question has nothing to do with triathlon performance, I’m strictly looking to build muscle for the sake of building muscle.
After college I managed to bulk up to 200lbs (from 150) in about 5 years, topping out at over 300lbs on the bench press. I then slimmed up again as I returned to running and eventually triathlon (getting down to 158).
Anyway, I’ll be honest…I’ve got a high school reunion coming up and want to look buff again! ; ^ ) What would you say the key supplements to take are? I don’t want to go nuts with this, just looking for the top two or three.
When I was lifting a lot 12 years ago, I’d have to say that the two most important ones were probably multiple 20g doses of protein powder several times a day, and limited amounts of creatine (I think it was 5g a day, but for no longer than 12 weeks). I would think those were the big two, and I did see huge gains after I started taking them. Beyond that I was taking a recovery drink, and a lot of weight gainer. I’m 38 and…uh…don’t quite have the problem gaining the weight anymore, so I think I’ll save my money on the beefcake mix this time around.
How much has changed sine then? For all I know they may have outlawed creatine since then.
Terrible workout. You want to look bigger then you have to train more muscles. I see no squat or deadlift listed. Chest and tris? Why not just do a pump class while your at it?
If you want to look bigger you have to BE bigger. That means eating. A lot. Supplementation is good at draining your funds (with the only expecting being creatine). Google “GOMAD”. Actually Google “Starting Strength” and read the forums there.
In all seriousness, once I get the muscle put on I’ll probably go to a system like you recommend to help balance keeping the weight off and staying tone.
Already got them up, dave! I’m practicing kissing my biceps.
I’d do that if I had biceps… Really though, you ought to start a 20yr reunion thread in the LR and see what those who went actually found/thought. I think you’ll be out of step going in as a dink and one who is not 40lbs overweight.
The excercise regimen works well and I had some great results from it.
BTW, lots of documentation and refrences for the anal retentive.
Also, if you drill down to the exercise listings for muscle groups, they have a encyclopedic list of muscle groups and associated lifts that work that group, including optional versions.
I’m pretty sure the DINK status isn’t going to change between now and then. I know you aren’t up on your biology, but you can’t make a kid in 6 weeks. ; ^ )
And FWIW, I was joking about looking good for the reunion. I’ve just been in the mood to get back into lifting.
