I have a new set of wheels that I’m setting up and it is my first time doing so with disk brakes and SRAM XDR.
The current rotors are within spec but have a slight bend and rub, so I want to put new rotors on the new wheels. I’m shopping for SRAM Force 1x center lock 160mm and there is a huge selection. I gather that the Shimano and SRAM are interchangeable? How is the performance? How far down market can you go and still feel confident in the brakes? These are expensive, more per rotor than I pay for my M3!
What about tools? I’m swapping the cassette over from the stock wheelset. Is the tool the same as the one used for the rotor lock ring? I’d rather not keep running out to a shop to buy tools to complete the job.
If there’s a difference in performance, I haven’t noticed it, though I’ve only used the top two tiers of Shimano/SRAM rotors, never tried something truly low end.
First off, as you say rotors are expensive, so if it’s just a bit of warp/rub then a rotor truing spanner may be the better option.
Regarding the lockring tools, then yes, in theory the same as the cassette, but be aware that if you got your cassette tool a while ago (ie >10years) then there is the chance the inner will be too small and foul on some hubs.
Regarding interchangeability and cost, that’s a hard one. But of all the bits that I’d seek to economise on then a rotor that has a very very long life and so a very low $/km cost (compared to tyres, chain, etc) isn’t where I’d start. But your money, your call. And perhaps depends if you live in Holland vs the Alps.
SRAM rotors are 1.85-2mm thick and recommended replacement thickness is 1.55mm
Shimano rotors are 1.8mm out of the box, to go with the Shimano replacement depth of 1.5mm.
It doesn’t seem like much, but it’s there and it can work for or against you.
What’s the typical life span of a Shimano Rotor and pads? I’m new to disc brakes this year…what’s the way to measure as a litmus test, on when it’s time to put in new pads?
You can just look at them. If the pad material is worn close to metal, throw them out.
Sometime when pads foul and refuse to stop squealing I toss them. I’ll usually try to wear them out a bit to see if it resolves.
It’s tremendously variable. I’ve killed a set of pads in less than an hour of cross racing, and I’ve had the same set of pads on my road bike for well over a year. Visual inspection of the pads periodically will give you an idea of what your wear rate is like. Replace them before the wear reaches the level of the return springs.
Rotor life is similarly variable (although much longer, generally). Measure the thickness, replace when they hit the manufacturer minimum. When you measure them, don’t forget that you need to measure where the contact patch is. I’ve seen a fair number of rotors that had worn to well below safe thickness but people still thought they were fine because they were measuring at the outside edge of the rotor, where the pads never made contact.
New wheels, tires, rotors, pads, and cassette. All very simple. It looks amazing.
Only issue is that no matter what I do, the pads and rotors drag and it’s unridable. I’m on the verge of raising the white flag and taking it to a shop for help.
The way I align the brakes is to loosen the brake bolts slightly, then hold the brake lever in so the brakes are on stongly, whilst holding the lever in, tighten the bolts with my other hand. When you release the lever the calipers/pads retract and the rotor is centred it the gap.
The rotor could be bent. I had a brand new shimano rotor that for the life of me I could not get to not rub no matter how many times I recentered the brakes. Eventually took it to my mechanic and he fixed it in 2 minutes after seeing the rotor wasn’t 100% true. I still need to buy that rotor bending tool.
