i heard they fit and i heard they dont. does any one have these two setup together. if so, how did you make them fit?
My LBS tried to install them and said they wouldn’t fit. I went with Cane Creek. They might fit if you are willing to take a dremel to them.
They definitely fit. I have this setup. 5 guys I know have this setup. Call Zipp to confirm if you are that worried.
It’s possible that Zipp retooled the mold once SRAM released the brake levers to fit them. The vukabull base bar that I have definitely has a smaller diameter hole than is typical. BUT, I don’t have any SRAM levers to test. So, if you have an older Vukabull, I’d call Zipp. If you are considering buying that set-up, then it’s probably a safe bet based off what others have written.
