Sram S60 / S80 Freehub Conversion (10 Speed to 11 Speed)
I purchased the Reynolds 11 Speed Freehub body (https://www.jensonusa.com/...1-Speed-Freehub-Body) after reading that it an upgrade path for Sram S60 / S80 rear wheels. However after purchase and installation, this increased the axle width to 134mm and will require a redish of 5mm to the drive train side. The kit includes 2 end caps and I only used the drive side end cap (I tried using the original end cap on drive side but the chain doesn’t have enough clearance against the chainstay). If there a seperate non-drive side end cap that is required? I scowled the web and I did not find any information on the install process other than it worked. Is there anything I am missing? I understand the wheel is 10 years old but would love to still get use out of them.
Not sure if the Reynolds freehub will fit your sram wheel, but before you do any re-dishing or further mods, this will give you some other good options for getting your 10s wheel to work with 11s (and then you can sell your Reynolds freehub … ):
https://darkspeedworks.com/blog-11speed.htm
