Exactly. All of that anti-disc brake mess and then Kiley proves everyone wrong…except me
This just means we need new bars designed to work with these levers.
Is your interpretation of the test that disc brakes are faster?
From the Lava Magazine article
“Consistent braking in all conditions, it’s the perfect setup. I think once people try disc brakes, and experience the, they’ll realize how much they want it,†said Declan Doyle, marketing manager with Zipp and SRAM. “The future of the bicycle—for both road and tri—is with disc brakes.â€
Correction as it is not the first time it has been done but it is the first time they have done it and it looks like shit. Now this looks much better. Sram could have done something like this and designed it to allow install of the Blip if required.
I’m not trying to pile on here but serious question. What do you think the test proved with regard to you being “right”? I can’t remember exactly what you claimed with respect to P5x except that disc brakes are the thing of the future. I think there is relatively little debate about that point.
As to the test, it seems to me that it showed the P5x to be the fastest bike with that set up which doesn’t necessarily mean that disc brakes are the fastest set up. What am I missing in your point/chain of logic?
Everyone claimed disc brakes were slow, P5-X wouldn’t beat the P5, etc. I said trust Cervelo’s engineering team and that disc brakes aren’t slow.
I completely agree.
Not really what i was referring to.
To be clear: Is your interpretation of the “aerobike-shootout-age-of-peak-aero test” that disc brakes are faster?
Anyway, the test obviously does not show that, and I was basically just trying to establish some common understanding for a future productive discussion.
Not sure but it looks much cleaner. Looks like it will only work with straight extensions but then again really the sram ones would only be practical on the say straight extensions or be a huge sales on an upturned extension.
Everyone claimed Cervelo rigged the test in their favor. Kiley tested with a minimalist setup to how he would race. The P5-X still came out on top.
Claiming “disc brakes are faster” is perhaps the wrong way to say that because the Andean didn’t beat the P5. A better way is “a bike designed around disc brakes” can be faster than rim brakes.
First of all, the only question the test addresses specifically is which setup (as a whole) is fastest for the specific tester. Second, the two fastest full systems are within the margin of error, so statistically they are not significantly different.
You may be convinced one of two fastest systems is indeed the fastest, and it may be true. The P5x certainly trends in the right direction. But utilizing that conclusion to say anything specifically about disc brakes is completely unfounded.
Everyone knew this test was all about Kiley and his setup. The test clearly shows what is fastest for him and if you believe otherwise, well that’s on you.
Yes, I know about that.
A bike that is fast as a P5 with better brakes is a win.
More bikes coming out with disc brakes will test faster than their rim brake predecessors.
Ok but you do realize, again, that the tedt didn’t show that disc brakes are fastest, only that the P5x, as an entire unit, is the fastest. While some may have argued that wouldn’t happen because of the disc brakes (and so they were “wrong”), likewise the conclusion that the test proves disc brakes are the fastest is also faulty.
Which is why I corrected myself earlier in the thread. A bicycle designed around disc brakes can be faster than a rim brake version. Does that make everyone happy? I assumed you all knew what I meant by saying disc brakes can be faster but I guess not.
No, again this is wrong. To show that would require you designed two new bicycles from the ground up (by the same team, same resources, etc etc), with the only difference in design parameters being a) must have disc brakes and b) must have rim brakes.
As long as you mix all of these things up, it is very difficult to have a relevant discusion, about anything.
