Is anyone using this feature? I’ve really enjoyed wireless electronic shifting but have yet to try this feature. I’ll probably give it a try on my next IRL ride. Care to share your experience, particularly with respect to how it works on hills? Thanks.
Yep, use it all the time
Originally had set up as sequential shifting but didn’t like where SRAM had set up the point to drop from the big ring to the small ring
Then used compensating shift mode with two gear compensation but depending on where you are on the cassette, I felt like two gears was too much, so now have it set to 1 gear compensate and it works well and the 1 gear is the right amount of compensation for most of the time I need it.
Try it for yourself, and you may find that 2 gear compensation might suit you better
Thanks for the information and insight. I will start with the 2 max shift and and then experiment with the single shift.
I’ve not tried this, but they don’t allow that to be changed? Shimano I can make it anywhere.
When I had it set up, no
The firmware has had several updates since then so it wouldn’t surprise me if I can now, but at the time, no
I really like it. I have it set to move one cog.
Good to know. Thanks.
