A friend of mine was given an old Specialized Tri spoke rear wheel - sweet looking wheel, but the hub is a bit dated. It is actually threaded for a freewheel, rather than a cassette. Does anyone out there know if this hub can be replaced or retrofitted? To complicate things, he rides Campy 10…
I am not sure about the retofitt but the old trispokes could be used as front or rear just call Hed and get a front axle for around $15.00 Randall
I kow it can’t be done with the older 7 sp freewheel discs because the hub is molded into the wheel. Probably the same with the tri-spoke but you should give HED a call just to be sure.
