I just purchased a Sitero 2 and the Reserve Rack doesn’t appear to be a great design, unless I’m missing something. The rack hangs so low that it contacts the seat post, and doesn’t allow me to push the seat forward into the necessary place for my fit. I did not have this issue with the original Sitero.
Anyone run into this issue and find a solution? Or do I need to go to an aftermarket rear mount like XLab? Thanks.
Looks like you have it right and it is a nice, clean mount in the right place. I just don’t think they counted on you needing to run the post in the reverse/forward direction and then having the seat slammed forward from there. I would be fine on my fit and even 4-5cm forward even further.
The Sitero 2 has two holes that bolt directly to the reserve rack. It does not clamp to the rails like the after market version. This rack came with the Sitero 2 packaging.
DFW_Tri, do you have a photo of how your reserve rack is mounted to your saddle?
I should know; I have it!! I have turned upside down the reserve rack that doesn’t attach directly like this one though.
I have a reserve rack bought this year and his certainly looks upside down. I’m looking at mine now. It just might be incompatible with that saddle.
The metal clamp to the saddle rails. Flip it, slide it down a touch, and try again. In my photo, old junk saddle but you get the idea.
I don’t sorry; my bike isn’t set up right now but it would look like yours but no clearance issues…before I had the Sitero, I also owned a reserve rack and was able to mount upside down.
Although I don’t have the same clearance issues as you, I really don’t like my reserve rack - I find it extremely hard to reach and replace the bottles on the fly…They are just too low for me. It’s a shame because apart from that it’s great. I just wish you could reverse it.
Yes it does seem this new rack mounts much lower. Never had a clearance issues or problems grabbing bottles with the original Sitero. If this new saddle is an improvement comfort wise, I will try an xlab Delta bottle rack. Thanks everyone.
I would like to see a video of you riding your bike.
You’re on a saddle that is designed to be sat off the front of, meaning it’s designed to be pushed back further than a longer saddle, yet you have yours pushed pretty far forward on a forward offset seatpost. I’m guessing your pelvis is not rotated, meaning your hips are vertical and your pelvis is arched shortening your reach which needs a saddle that’s further forward.
Can you post?
Eric
Can you post?
Eric
Eric, in fairness to the OP but not knowing his position, I had a very similar issue on my old Dimond Brilliant and my position was in line with your methodology. The reserve rack on the Sitero did not play well with the Dimond Brilliant’s seat post. I had to slide the saddle so far back to make the reserve rack not hit the odd shape of the seat post that I could barely sit on the saddle. So I had to ditch the reserve rack. That was rectified with the Dimond Marquise’s new seat post that allows for way more adjustability and range.
Can you post?
Eric
The google photos are blocked here, but I was about ask the same question. I have the original Sitero and reserve pack on a Transition and it looks just like the first picture posted of the example. It comes close to hitting my seat post but still clears, and I have the back facing post with the saddle in the 3/4 forward position, so the back of the rails are close to the post clamp. If the OP is hitting his stem he must have the saddle slammed way forward.
I sent Eric an email with my fitmap. I have no issues with the original Sitero – with the reserve rack on the original, you have full use of the entire seat rail.
The Sitero 2 reserve rack bumps into my forward seat post halfway into the rail. So you basically lose the ability to move the seat forward past the halfway point of the rail. I don’t think that qualifies as slamming the seat forward. Thanks all!
Can you post?
Eric
Have a Sitero with alloy rails (comp?) On a shiv with 12.5 seat post (reversed) and was having no issues aside from a little rub on the post which I solved with some black electrical tape.
Here is where everything changed. Bought a new sitero carbon (great deal on it) because I wanted to put a sitero on my other bike. Got to thinking I would put the carbon on the shiv since its my event bike and I actually use it the most and put the allow on the other bike. I got the new sitero in my hand only to find out that this carbon model (there are 2) is not compatible with the reserve rack that holds 2 bottle cages. I spend 2 hours on the phone with rider care, who basically thought I was smoking crack when I told them it doesnt fit. Thats how we discovered there are 2 sitero pro models, one works with the reserve rack and one works with direct mount reserve rack (holds 2 bottle cages).
So I was like whatever, ill put the carbon on my other bike and the allow back on the shiv. Ok fine, but now I swapped out my seat post to the 37.5 just as the OP has and there is no way it will fit just because the seat is so forward. What I decided I need to do it just get some metal and make some extensions/wings so the direct mount reserve rack will be extended slightly back and I should be back in business.
Some of you may be wondering why go through the hassle. Well, I have a really good fit with the 37.5 forward and sitero and just need 2 bottles on the bike (and fuelselage) to carry as much hydration/nutrition as possible.
So back to the OP, Im in the same exact situation as you and just plan to get some strong metal strips and build like a 2 to 3 inch extension off the saddle and hopefully with the right length screws and loctite it will hold. I actually got longer screws and mounted the direct mount reserve rack to the carbon sitero and it worked so I think with these adhoc extenders it will work with the 37.5 seat post.
Same issue… I just switched to the new Sitero Pro (from the older Sitero Pro). I am using the “normal” setback post but flipped so it is in the more forward position. In my case I think I can cut away a bit of material on the bottom of the mount and it might work but haven’t gotten around to trying it out yet. I was really disappointed to discover the change on the new model :-// clearly a bad design but the same setup they use on the Power saddle. The old Sitero Alloy had the same issue (it used the same reserve rack)… I think it was only the old carbon Sitero that used the much better three point design.
The older carbon sitero with the 3 point design is not compatible with the direct mount reserve rack (which can hold 2 bottle cages), it is compatible with the reserve rack which can fit one bottle cage and the wing for air tools, but it also has its own rack so you dont even need the reserve rack…I can post pictures, but this is what I was saying, specialized ride care thought I was on crack when I told them the mount reserve doesnt fit on the sitero pro, not realizing there was 2 different pro siteros. I made it fit with longer screws and spacers…and it was fine, but not with the 37.5 forward seat post.
Not a great photo… but here are the two side by side.
.jpg"]
