Anyone have an info/opinions comparing the two? I’ve read several reviews, but I haven’t been able to find any aero data comaring them. I have the Specialized, but I am intrigued by the short/no tail design helmets. Wondering if anyone has any experience wit the two. Thanks.
There is no point comparing other people’s data on helmets.
I’ve tested both and one was quite a bit faster for me, but this has no bearing on how they’ll work for you.
This x 1000
Why there are dog aero helmets out there that should be avoided, I’m talking to you Giro Air Attack & Rudy Project, if you’re not going to test buy the one you think is the most awesome looking or matches your kit the best or makes you feel the prettiest.
I am a long time user of this forum but this is my first post. I felt inclined to respond to this specifically because I was in your shoes (err, head space…). I was fortunate enough to work with my LBS and an online shop (with a good return policy) and tested my road helmet against both the Sworks TT and the POC cerebel (note the giro aerohead wasn’t available at the time). Below is a short summary of my pros/cons.
- on any given day / course, either visor is going to fog but the Cerebel is easier to take off and wipe clean. On my test day I couldnt get either to fog but ive had races where my helmet of choice fogged so badly i had to tuck the visor into my jersey
- both have a snub tail design so looking around isnt going to be as much of a penalty. The overall aero efficiency will be based on your position though (as mentioned in other answers above). For me, the Cerebel was faster
- comfort wise, once both were adjusted, i could not really differentiate between the two. the ear flaps on the Sworks are definitely harder to get over your ears in a quick transition and did
- on the road, visibility while head tucked was in favor of the cerebel. the visor is just longer and allows for more forward visibility
- ROAD NOISE. This was the biggest for me. I found the wind and buffeting in the sworks to be annoying. I dont feel claustrophobic or have trouble hearing in either one. But at speed, especially on descents, i found the sworks to sound like a jet engine inside the helmet. Please note, this could be that the sworks was not conducive to my position, and as such created more noise.
in short, i went with the Cerebel… Hope this helps…
If there is a rule of thumb it is that short tail helmets tend to be better if you look down a lot. If you turtle reasonably well, then I would keep the Specialized. If you look down , which you shouldn’t be doing but that is a different matter, the POC.
Agree completely. We are starting to see companies that provide mobile aero testing (STAC & velogicfit) per se that should help with such purposes as aerohelmets are really a n=1 sort of purchase depending on your position. If you can’t do this, then Mike’s post is a good rule of thumb.
