I got a set of Bontrager Aeolus 7 tubular wheels.
It’s basically built on DT swiss 180 hub.
(new version comes with 240 maybe…)
I really enjoyed it but sometimes…
When I kick a pedal with sprit,
crank arm spins together…
Other dt swiss users call this phenomenon
“Sticky hub”
So I disassembled the rear hub,
took out 2 ratchets and 2 conical springs,
wiped them out
and lubed them with dry-type chain oil.
It works superbly not showig the problem.
- The ratchet sound got louder than before.
Actually I am little bit worried about “using chain lube” instead of dt specific grease…
Is anyone who had a similar problem here?
How did you solve it?
