I recently purchased a Sole F80 and for some reason it feels like the treadmill has an incline to it. (Roughly 1%)
The treadmill itself says 0 incline. I did a calibration and that didn’t help.
Any further suggestions?
Thanks!
Thanks!
I would agree with you on my experience with the same treadmill. I would suggest you embrace it and run as is. it will make your road experience an easier transition.
You don’t notice it after a while.
Agreed on my end!
My wife, not so much … she wants it a true 0% ![]()
sole F80 was put in the garage last week. same thing… seems to be an ever so slight incline with my long level.
i was planning on doing some adjusting when i have time to try and get it just right.
Hi, this is really easily solved. Almost any treadmill grade can be adjusted by putting a wooden block under the front (steeper) or rear (flatter). So a 1-2inch block should even it out. However 1% is actually more beneficial, watch this video for some nice info on incline benefits: https://www.youtube.com/watch?v=XImO3h7ttvw
I have a Sole F63 and would be willing to bet it is also at 1% when it states 0 incline.
Embrace the 1 % incline. You will find road running more enjoyable and less frustrating with the speed boost.
I run my sole f80 at 3% minimum for everything. I feel like im on steroids when I go outdoors.
I’m convinced that my Landice at 0% is similar to most treadmills at 2%. If I run at the gym I put them at 2% to start and it’s no big deal. If I set my home TM at 2%, I’m working.
If your wife is really upset by the perceived 1% incline, head to the hardware store, buy one of those wooden yardsticks and put it under the back feet of the TM and your problem should be solved.
most treadmills need to be somewhere between 1-1.5% incline to mimic normal outdoor neural motor patterning.
They seem to ship this way (with the feet bottomed out (up) and therefore the default is an incline… just turn the adjustable feet on the back of the treadmill till it is level. Leveled mine out perfectly.
Love my Sole F85… we have put 600 miles on it in the first year. The software the runs the display needs some work but at the end of the day the treadmill does what it is suppose to do.
I think it’s designed that way on purpose. i added some shims in the form of extra foam mat blocks and a piece of wood on the rear of my f80
