SRAM Force eTap AXS Groupset-2x12 Hydraulic Disc Brake/Shift Levers
Kit was removed from a new bike build and swapped for a SRAM RED AXS upgrade.
Kit has never been ridden and a chain was never installed through either derailleur
**Calipers will need re-bleeding **
This SRAM Force eTap AXS Road HRD Group includes:
**Right FORCE eTap AXS **Hydraulic ETAP shift/brake lever (1780mm cable length)**Left ****FORCE eTap AXS **Hydraulic ETAP shift/brake lever (915mm cable length)**Front and rear FORCE AXS **disc caliper and pads (160mm flat mount front adapter NOT INCLUDED but available retail for $20.00)**Rear FORCE AXS **disc caliper and pads (160mm flat mount rear adapter is INCLUDED)**Front FORCE eTap AXS **Derailleur and battery (derailleur mounting bolt, washer and shim kit **NOT INCLUDED but **available retail for $35.00)**Rear FORCE eTap AXS Derailleur and batteryCharger and cord ****(2) Sram hydraulic brake line barbs, (2) olives and Sram Barb installation tool ****Sram Bleed block **(bottom bracket, disc rotors, crankset, cassette, and chain are NOT INCLUDED)
