SOLD: Bontrager RXL Carbon Basebar, Full riser kit, PD Carbon Cobra Extensions
FS is a full carbon cockpit setup. Its awesome, but its a hair too wide for me at 42cm c-2-c; so I switched to a 40cm setup.
$325 shipped CONUS OBO.
Basebar is Bontrager RXL Carbon - in nearly flawless condition. This model: http://www.bontrager.com/model/09883
The only marks are from the stem clamp and will be covered when put back in a stem . Includes full riser kit - 2 pairs of 10 mm risers, 1 pair of 20mm risers, bolts to go from no rise to all the way up as currently shown in photo.
The PD T2+ Cobra Carbon extensions are uncut; the only mark is some cosmetic scratches towards the butt of one extension from removing the original PD clip-on bracket. These extensions have actually never been used and are in new condition aside from that.
Also includes the PD clip-on clamps, risers, and pads for the PD extensions if you want to pull/swap the extensions and use them on a different setup. (set of accessories to the left of the bar setup)
The bontrager pads on the setup are usable - they aren’t toasted yet - but could use a fresh pair.
I can send closeup pics of anything you’d like. Just send a PM.
http://i58.tinypic.com/2645ld3.jpg
bump
