That’s right, the world’s fastest bike!! Well, except for the others claiming to be the world’s fastest bike…
I’m selling the frame, fork, seatpost, and the SRM mount. The other stuff is not included! 54CM, 700C wheels.
The bike was about 300 miles on it. However, it has hundreds of miles traveling in the back of giant wagon, so there are some superficial (light) scratches. Overall, I’d say the condition is cosmetically ‘very good’, but if you want absolutely perfect, look elsewhere. Functionally, it’s perfect. The fork has approximately 60mm sticking out, so if you use a conventional stem there’s room for a spacer, but not a bunch.
The front hole on the seatpost has never even been used!
There is a wired SRM mount internally mounted. This required drilling a small hole near the rear derailleur cable, OK’d by Cervelo. It doesn’t touch carbon (the insert there is aluminum). If you don’t use an SRM the derailleur cable will cover the hole. I’m leaving it in if an SRM users buys it.
