So is there really a big difference between the cervelo dual and p2K?
trying to decide between the two- of course the p2k has the rear wheel cutout, but is that REALLY going to cause a difference? anyone ridden both of these and was able to tell a difference? seems like the dual is a great deal-
Thanks for the input before I shell out the $$$!
They are both great bikes, given the same components, I would go with the dual. Be sure that the fit works for you.
i had a friend that was looking @ the two of them. for her, it was a little more than that.
the dual comes in 700c only, she needed 650. as well, the cutout, and i think the dropouts are different. i tihnk weight might be different too. head tube size.
p2k is further along the ‘ladder’ for a reason…how much difference that makes to you…is up to you.
I would suggest the primary differenc is the seat stays. The stay on the P2k seem a triffle shorter and angled downward slightly more. The stays on the Dual are more upright in angle and join the rear triangle right at the seatpost clamp area of the frame, higher than the P2K.
The result of this may be different ride characteristics. I would suggest the P2K could be stiffer at the bottom bracket due to the tighter rear triangle and more material at the bottom bracketdue to the aero seat tube but also slightly more comfortable since the seat stays don’t cut as direct a line to the seatpost clamp area.
So, there may be some difference is rider characteristic for you.
As for aerodynamics, while I am confident in saying the seat tube design on a P3 is a significant enough difference to make the bike more aerodynamic than a round tube bike I doubt the semi-aero (doesn’t wrap fully around wheel like P3) seat tube of the P2k exerts as dramatic an affect as the P3’s aero seat tube.
That said, the P2k is a great unsung hero of the Cervelo line. It is the middle child that arely gets the attention it deserves. Nice frame, nice parts, solid bike. I’d rather have a P2K than Dual.
ok, thank you guys for the responses- I appreciate it, and that definitely helps. both look like great bikes, didn’t realize the rear triangle was any different. may come down to a budget thing, but the p2k is looking pretty nice right now.
cheers
Went through the same process this past August with my heart set on the P2K. Tried them both and couldn’t tell the difference. The $$$difference$$$ was used to buy some nice wheels.
Jay
Oh duhhhh, ended up with the Dual.
cheers
I second what Tom said, and was going to say the same thing regarding the effects of the rear triangle before he said it first. I have a P2K, and the bike handles… well! I think it’s a great all-rounder, that’s aero on the flats, and climbs and descends with the best of them.
Slowman wrote a good article about the Dual in a tri magazine not long ago.
IMO, you can’t go wrong with either. I own a P2K but wonder how much difference the rear wheel cut out and shorter seat stays make to the average AG’er. If you don’t ride really low in the front it might make more sense to go for the Dual. For the same money for a P2K you could also pick up a set of used aero wheels off ebay with the Dual.
Dual comes in 650.
Dual comes in 650.
only one size 48, the p2k come in three 48,51,54.
call me an elitist but i would buy the p2k on the components alone.
