Hi all
Anyone have a recommendation for a small electric bike pump with gauge that has an extender small enough to fit a disk wheel ?
bought one and the extender does not bend such that I can fit it to my disk wheel valve
Thanks in advance
Hi all
Thanks in advance
i have this one, comes with a mini hose attachment. easy to pump up a disc wheel (instead of using crack pipe). i use it on my hed disc
Fumpa Bike Pump – Fumpa Pumps USA
maybe you need to buy this part too… honestly i forgot
I would use a regular pump with a crack pipe.
I ended up getting the Lezyne Micro Floor Drive Lite. It’s compact, has a gauge, and the hose is flexible enough to fit around disk wheel valves.
I have a floor pump and a pipe but not ideal for travel , the Fumpa looks promising thx
We gifted this Fumpa pump with digital display and their disc wheel nozzle https://www.fumpapumps.com/products/disc-wheel-extension-nozzle
To Sam, Rudy and Trevor for travel to races, and I have one personally and love the pressure gauge accuracy. Travel and race morning must-have
I think you meanth this in stead of the elbow nozzle kit?:
It’s like if I was 100% going to buy an EV pickup and asking for recommendations and Jim suggested a 1995 F-150 with a V8 gas powered engine.
That part did not exist when I bought my fumpa in 2022, very cool
same here, I just ordered it
Before I was attaching a crack pipe to the one you linked.
I have one of these. It comes with a short hose that screws on to my crack pipe. It’s brilliant.
What informed my decision: Threaded #22: The best portable cordless tyre inflators - Escape Collective
I wanted the digital display to be spot on accurate in terms of actual tire pressure
Fits in my Aeron x with no additional adapter.
That link is behind a paywall. What were the top recommendations?
Based on the article, I went with the Fumpa because of gauge accuracy. In opinion, if I am traveling, and especially if I am racing, I want that tire pressure number to be spot on accurate without having to pull out a separate pressure gauge device.
For a very tight disc wheel (FFWD), I am using a Fumpa + Fumpa’s dual head extension nozzle + Prestacycle Disc Wheel Mini Presta Head. The Prestacycle chuck is the only one I’ve found that really fits, but it doesn’t lock on so is a pain to use with a track pump. With the Fumpa, it’s pretty easy.
