Skim coat concrete drive way, anyone do it?
My concrete drive needs some love,just a few small cracks which I filled.
Looks like a couple of different brands with same process.
Who has some experience with this process?
Make sure it’s done correctly or it will just pop off.
You’ll want to make sure existing concrete is power washed.
Then you’ll need a two part process-adhesive and then topping. Even then, no guarantees.
It is likely to crack and fall off.
This. I wouldn’t do it, personally. It’s a bandaid solution you will most likely have to redo sooner than you would hope.
Used to sell everything concrete related. There’s a product called Ardex CD that has epoxy in it. You can skim it to 1/8” and it’ll bond to existing. I’ve hit it with sledges and it doesn’t break. Sold truck loads of the stuff after spec housing dev. Ran a sweeper through while the slabs were curing. Red clay dirt turned the driveways red. Cheaper than a repour. This was 35yrs ago and it’s still in tact. Incredible stuff.
This made me chuckle pretty good. I bet that was an awesome Friday afternoon when that happened. (I’m assuming that’s when it happened… That sounds like a Friday afternoon fuck up kind of story).
Interesting about Ardex CD. Never heard of that product. I would think after a couple years of freeze/thawing and being driven over that would just delaminate from the original slab in chunks.
^^^^^^^^^^^^^^THIS^^^^^^^^^^^^^^^
Ardex is good stuff, coming from northern Utah.
I think of Ardex as self leveling floor compound.
We use “Ardex” in the same way people use “Kleenex” for tissue.
