Ski bar extensions
Does anyone know where I can get aluminium/alloy ski bar extensions from looking for around 30-45 degree angle
Profile Design T4+ Aluminum: 30 degrees
What degree bends do you think these are?
http://cyclingweekly.media.ipcdigital.co.uk/11141/0000043a8/a2cd_orh213w269/v10-st17-MILLAR-1.jpg
They are mainly the ones im after
USE makes a variety of different bends from 20 to 50 degrees. You could always insert the extensions backward to get a little more rise too.
http://www.wiggle.co.uk/use-tula-alloy-extensions/
http://www.wiggle.co.uk/...la-alloy-extensions/
Ok thats cool anything I have to look out for it terms of compatible with my current bars, not sure on the width of the s bends I have probably the standard 22m?
http://cyclingweekly.media.ipcdigital.co.uk/...10-st17-MILLAR-1.jpg
Millar’s are 45deg. bends.
If you are interested, I have some 45deg. bends that are takeoffs from a Profile Carbon-X bar. They are carbon, but priced to move.
If you are interested, I have some 45deg. bends that are takeoffs from a Profile Carbon-X bar. They are carbon, but priced to move. sorry I’m going off carbon. Especially for bars stems and seatposts
NP, just find some 45deg. aluminum ones. FWIW, Zipp Vuka alumina extensions are 40deg. (what I have on my current race bike). Profile T1+ are 45deg. (the same design as the Carbon-X, but in alum.): http://www.performancebike.com/bikes/Product_10052_10551_1169610_-1___000000
Personally I skip carbon road bars (breakage concerns) and seatposts (slippage). I’m OK with extensions since I don’t really pull on them.
If u were to buy these 50 degree bends and put them in backwards would thar be the same as the picture I posted earlier?
Flipping the bars won’t change the angle, you’ll just get more rise and less reach. Looking at Millar’s bars, he’s using the standard mounting to get the extension length he needs.
As to if the bars will work, no way to know without knowing what hand placement you want relative to the pads (Xcm forward, Ycm up).
i have some zipp carbon extensions to get rid of. PM me if interested.
I would get a pair of U.S.E. extension, The best bars I have used.
these? http://www.wiggle.co.uk/use-tula-alloy-extensions/ can I flip the 50degree bends around?
these? http://www.wiggle.co.uk/...la-alloy-extensions/ can I flip the 50degree bends around?
I haven’t tried the Alloy ones, only Carbon but they should work. Its a super common setup with the fast guys in England. Witness the Magic man and his setup
http://i48.photobucket.com/albums/f236/roc-dude/magic%20man%20TT.jpeg
these are the bars i currently i have http://www.wiggle.co.uk/pro-synop-tt-base-and-clip-on-aerobars/ would the extensions below fit them?
make your own. Cheapest (especially if you can borrow a pipe bender) way to get exactly what you want.
make your own. Cheapest (especially if you can borrow a pipe bender) way to get exactly what you want. Ill be honest id rather just spend
barring that, the USE are indeed probably what you are looking for
Check out the Zipp Vuka Alumina Evo 110 extensions: http://www.zipp.com/bars/vuka-alumina-extensions/
May be interested in your bars. Send me info?
Thanks.
