Hi everyone,
Having an issue deciding what way to go.
I finally got the go ahead from my wife to purchase a power meter. I’m 98% set on the Favero Assioma pedals.
What I forgot to mention to my wife is I need a bike computer to get the power data. I currently have a bontrager trip 100 and my Garmin 920 XT. Both of which will not connect to the pedals. Am I correct in saying that?
So, do I get the uno single side power and a new edge 530 which is about the same price as the duo or get the duo and try my luck at convincing her for another 300$ for the computer.
Is there a huge difference between single and dual or just slightly more accurate?
Any help will be greatly appreciated.
Thanks team
Quinner
I think the Garmin will connect to the PM over ANT+.
Go for dual.
They (pedals) should connect to a 920 XT. You could look for used edge 500/520 on the classifieds to save money and to have a dedicated bike computer that will display power. you could also use your phone if you want to. Since they transmit in bluetooth as well.
The 920XT will connect to the Assioma dual.
The issue with a dual/total power meter versus a single-sided meter is that it will be off by double your power imbalance. For example, if you have a 55%/45% left-right power balance, a single-sided PM will be wrong by 10%. And further, your power imbalance will move around depending on stress, recovery, interval strength, etc. So, the accuracy could float anywhere between 5% to 10% off for a lot of people.
All that said, the foundation is that you are training and racing on a consistent power measure. So, if you are training on a single-sided meter and you are racing, the problem of being wrong is minimized because at least it will be consistent.
Get the dual and pickup a used Garmin 500/520 for like $50
^ Do this. I have a single sided bePro and a dual sided assiomas (different bikes). When I ride the bikes on my direto, the assiomas are always within 5W of the direto. The BePro is +/- 20W (my left leg is longer and stronger than my right leg).
Also, the assiomas should connect to the 920XT.
I have Assioma and it is working fine with Fenix and my father’s Assioma is paired with 920xt and Bontrager node 2.1
I’ll buy Edge 520 for 50$
Get the dual. The assiomas will work great with the 920xt; it’s definitely easier to see power in real time on a bike computer though. My imbalance is not the same every ride. It depends what cadence I’m doing and even what bike I’m riding.
I used a 310 XT with a quick release kit as my main power display/data-acquisition device for the better part of two years before I finally got an Edge 520.
