So the fiber clumping issue was on us and existed within the first few months of production… the stuff plugs the bottling equipment and we had to work through 3 different bottling machines and suppliers before finding one that could handle the stuff. As a result, some bottles had too much carbon and some very little. The ones with too much carbon could lead to clumping, though even if the carbon did clump, the raw sealant will still test better than Stan’s and about equivalent to regular Orange Seal.
The DT/Zipp rim tape issue is something we initially thought was something related to us, but it now appears to be more related to something that was changed with the tape, most likely during covid related supply chain issues, as we did over a year of testing on the sealant in wheels using both Zipp and DT tapes without issue, but from mid 2020 onward began seeing issues. You can now find dozens of threads on MTB forums debating the identical delamination and discoloration issues with the rim tape using any of the common sealant brands. Seems that any sealant with any sort of particle leads to abrasion, and sealants with more particles like Stan’s raceday or SILCA just seem to do it a bit faster. You can read more here: https://singletrackworld.com/forum/topic/rim-tape-failure/
When we say tensilyzed polypropylene rim tape, that means anything like Stan’s yellow tape, Schwalbe blue, 3M, Tessa, etc… all of these tapes use similar TPP materials and are either made by 3M or Tessa, and all of them are significantly more durable than the PET/vinyl tapes that have logos printed on them… a good rule of thumb is that the good stuff is generally brightly colored, opaque, and has no logos on it as it cannot be printed on as the material will not hold ink.
Hmm I just bought some Silca sealant to try, but having read this post I am now wondering if it is worth actually installing it on my Zipp wheels if it is going to give me issues with the tape. Don’t want to be messing around trying to find some very specific new type of tape that might be better with Silca sealant. I live in Europe and am guessing it is probably hard to find the specific tape brands you listed. Have been using MucOff sealant for past 2 years since the wheels were new, this has not caused me any issues with my rim tape. What to do??
Clearly from the responses to this post so far, it is not so simple. Some say one type of tape works, others say it doesn’t…….all too hard quite honestly.
If Silca knew about these tape issues for 12 months+ then why on earth do they not put clear warnings about it on their product descriptions and packaging??? Just imagine if somebody had a catastrophic blowout that was caused by a tape issue, that in turn was caused by using Silca sealant then I suspect a judge in a product liability case would look very unfavourably on the manufacturer……especially when it is documented and even admitted to here on this forum that they have known for some considerable tape that THEIR sealant could cause problems with tubeless system effectiveness.
I think I might be returning my so far unopened bottle of their “super†sealant to avoid this issue for myself.
