Diamond polished, WS2 impinged, then ultrasonic waxed…will such a chain not only reduce drive chain power loss, BUT will it last longer and protect your drive train? I am assuming lower friction might mean lower chain wear?
Pretty soon wireless electronic groups will cost less than chains. $350 for the Ti YBN chain bundle. Ouch.
I’m sure the cost is justified based on the materials and work-hours, but this is one silca product that I will pass on. If i had the talent, desire, etc to go for an hour record then i’d probably have to think long and hard about this. It’s cool they are doing it…it’s just not a product for me.
I agree with you this will not work as a product for me but for some people it is a reasonable item to consider. When you look at basic numbers say that drive train losses are 1-2% of over all power, unless you are pushing 300 watts or more you are maybe saving less than (because the comparison is another prepared low friction chain not sure how that compares to the 1-2% drive train loss chain system)… does that mean you save say 1 or 2 watts by using this chain? over another prepared chain, or vs a normally lubed chain? I would love to know what it means for certain situations like plebeian 200 watts or pro 300+ watts of power input what does this chain save vs other chain prep options?
I have played around doing something similar in the past (but not with diamond dust as I am not a baller) - sadly don’t have a good setup to test efficiency gains/losses. I tell myself it’s faster though and that + the effort put into it has to count for some placebo watts at least.
It’s a niche product, but I would guess it has an audience. At a certain point of course, it’s hard to get that last percent of a percent of efficiency, at any cost.
The standard for testing comes from Ceramicspeed… and it’s watts of loss calculated on 250w input. 2.8-3.0w loss is really good… a Molten speed waxed DuraAce chain might cost 4.5 watts. A SecretBlend waxed DA chain will cost 3w and a Ceramicspeed prepped/waxed/powdered chain might do 2.8w. With this process, we can get that same DA chain into the 2-2.1w range, and if you maintain it properly, you can keep it under 2.5 w for thousands of km.
I should also point out that if you take out the cost of the SuperSecret Drip and the Secret Blend, our chain really isn’t all that much more expensive than some of the other offerings out there…but we feel you really need that other stuff to keep the investment running as long as possible.
I wonder how it compares to Dan’s Ultra Optimized Chain, which is a great chain and about half the cost: https://www.premierbike.com/...ucts/optimized-chain
It’s not half the cost when you factor in that you’re getting both the hot melt and drip lube as well.
I’ll weigh in - I have been doing metal finish optimization for a long long time (almost 20 years). Many sports, industries and products.
SILCA has a nice bundle. Thier chains are very very good - as are our Connex chains.
We carry the Connex 11 speed chain.
SILCA is offering a wide range of chains - so good on them for that. Thier bundle includes their drip wax and hot melt which is really what you need to keep a chain like this efficient, smooth and long lasting.
As for watt savings and driveline efficiency - our testing shows that a physicaly polished chain (plates, pins and rollers) gives you around 2.3 watts additional savings over a chain that has only been cleaned, run-in and waxed.
Very true. And I hope I wasn’t coming across as critical, I love Silca’s stuff. I’m just genuinely curious since I race with one of the Premier chains.
Thanks for the info Josh, for crude comparison what is a "normal out of the box chain watts loss? The other data is really informative. I also saw your video, again 10,000 km of life vs what one would expect from say a non prepared chain? what I seem to see on Adam’s site is the worst case is 1000 km life for a chain? so is it fair or accurate to say 5 or more (maybe 10x) the life of a normal untreated chain? So then the math starts to make sense for even punters like me?
maybe math is not my strong point but to me the cost is not that exorbitant if one assumes that the chain will last 3x longer than a typically prepared (home prepared) chain… chains say YBN cost about $50 so the YBN chain option with Silca is $225… then back out the costs of the added items ca $80 so that leaves 145 for a highly and carefully prepared chain. Then the math works at 3 chains, so if it did last 3x as long you are break even at worse case but you also get the benefit of a chain prep you can not do at home… the economics do not sound so bad and the upside is worth maybe a few watts saved or a few extra KPH each ride. God Josh please stop innovating! it is getting hard to explain to my spouse why I have so many Silca things!
So would one be able to extrapolate that taking a chain that has been ridden for some time, then degreased, cleaned, and lubed with this super special wax will save watts as well over a fresh chain?
To a point. As a chain is worn it - it streaches. When it streatches the high points of the metal surfaces move.
If a new chain is treated properly all the high points are eliminated creating a honed platue surface. If kept lubrucated the fast chain lasts longer as it streaches.
I may be wrong here, but my understanding is the source of the elongation of a chain is not that the metal actually stretched but that as the rollers wear they cause the chain to elongate. Now saying that the places where the outer plates touch each other does move in this case. I believe one of the fast chain companies does a run in before preparing with the super lubricants to glaze the surface but that is not the same as diamond polishing which physically removes the imperfections from the surfaces. I actually wonder if a run in would actually cause more problems than solutions because the imperfections may cause grooves in the opposite plate?
What I understand is the reason a well lubricated chain lasts longer is not due to stretch but rather the reduction in the wear of the roller and pin interfaces, so in fact it does not “stretch” since the elongation is the basis of chain replacement and therefore the longer it takes to reach the elongation point is a tribute to the quality of the lubrication to protect the pins and rollers from wear.
In the end this whole idea of polishing then impinging with WS2 is not really new it is just new in this application.
Wow that is very interesting data. So the old belief that chain loss in the whole picture of where your power goes of say 1-2% if off by a bit, for the worst case it is 3.6% and the best case it is 0.8% power loss due to the chain friction. That is eye opening. If I understand correctly then at the pedal you are inputting 150 watts and when the rubber hits the road so to speak there is worst case 241 watts and best case 248 watts actually moving the bike forward. Is that correct?
