Should I get rid of my tubulars? Are clinchers good enough now
I have a pair of 404 Firecrest tubulars that I hardly never use - and I’m having a hard time justifying keeping them. Is there really any clear benefit to using 404 tubulars over 404 clinchers now? I know they are a little bit lighter - and I do like the feeling of riding tubulars - but I don’t do road races any more, only do a couple triathlons a year and race a few crits. Nothing that I need an expensive wheelset that’s expensive to maintain… right?
so… Give me some advice. Can I use 404 clinchers for everything and get rid of tubulars or are there some races that I really should still use the for?
Yeah, you can use 404 clinchers for everything you do. About the only downside is if you do a lot of steep and long technical mountain descents where there are some concerns about overheating full carbon clincher rims and even then the Zipp FC rims are apparently some of the best when it comes to heat management and sidewall integrity.
Since you’re comparing the same 404 FC profile for either the tubular or clincher version there’s very little performance difference beyond a bit of weight and you’re right the clinchers are a lot more convenient.
As you hardly ever use them, why are they expensive to maintain?
You’ll take a massive hit selling on used race wheels, alas.
Just keep what you’ve got IMVHO.
If you must sell, well the obvious answer is any covered rear wheel and a Flo 90 front.
Why not keep the tubulars if they work for you? Clinchers can be faster but the difference is minimal if you already have a race set of wheels.
I have both and find I only ride the clinchers.
I used to race exclusively on tubulars but now it seems the aerodynamics are the same and the tires are too.
my experience with both have been good but the convenience of carbon clinchers makes it a simple choice
Tubulars are a huge pain in the a$#. I raced them for years. Good riddance. Clinchers far easier to work with.
And anybody tells you there is a difference in how they “feel” is full of crap.
I might keep some tubies around if I lived in colorado or california and races had huge climbs pretty often.
otherwise, not worth the hassle. You can get the same feeling of riding tubulars with good clincher tires and latex tubes.
Aren’t tubies also a bit more resistant to pinch flat in a pothole or such?
Maybe? I’ve seen tubies pinch flat, and I think I’ve pinch flatted a clincher maybe once in my life?
Don’t run over railroad ties and don’t underinflate your tires. Supposedly latex tubes are less likely to pinch flat but I don’t know if that is true.
Yeah, a bit and they can be a bit safer to ride to a stop after a complete blowout at speed and won’t blow out or have sidewall deformation from excessive braking on long technical descents (but can also get hot and melt the tubular glue holding the tires in place in similar heavy braking situations).
But all of those are pretty minor and tubulars are not markedly more robust or safer than clinchers run at appropriate pressures at least for road riding, now cyclocross tubulars run at very low pressures like 25-30 psi…that’s a different discussion.
-Dave
If you were buying today, no doubt that clincher would be the preference but I wouldn’t take the hit by selling them and buying new wheels. Ride 'em until they fall apart and then replace with clinchers.
Well pinch flatting is no fun. I hit something (rock?) last year at over 40mph in a race. Pinch flatted, front and rear latex tubes, THROUGH the tires, and destroyed rear rim. Clinchers inflated 5 miles prior. It sucked. Would a tubie have prevented that at speed? I doubt it, but maybe??? That was an expensive incident.
I’d agree with above that unless you have to have every gram of weight…what a pain in the butt tubies must be! Especially if you do happen to flat.
Are you buying 404s new? If so then between selling and buying its going to be between 500 and 1000. For a few crits and a few tris your looking at about 50 per race to change and you wont be any faster and might be a few seconds slower on hilly days.
You mention expensive to maintain butno way will this be cheaper unless you put in a lot of miles and wear through tires/tubes quickly.
Now if you can find someone to trade or sell and buy a much cheaper wheels set thats a different story.
Just to confirm, you have both 404 tubulars and 404 clinchers, both FC rims?
If yes, I’d keep the clinchers and sell the tubs.
Your problem is that you are riding those clinchers too much. You should just ride the tubbies all the time. I’ll hold onto the clinchers for you so you aren’t tempted to ride them. (Does this really need to be pink?)
Wait, you ripped through the clincher in this instance? That isn’t a pinch flat. That is just sucky luck. And yeah, unless your tubie was a Gatorskin of some sort it was likely going to happen.
I haven’t had good luck with latex tubes, but maybe I’m using the wrong brand - I had challenge tubes - but I’ll try some new ones.
Thanks for the advice. I love riding tubulars - and you’re right without flat they are great - but when they do flat (and the roads near me in NorCal aren’t very good) it’s a pain to replace the tire.
Very crappy luck correct.
sell the tubbies now, while they’re still worth something, rather than waiting 5 years and selling them for $1 reserve
