Shoks and Watts
I have a touch of arthritis in my lower back so I ride a Use Shok post which I like - I’ve always reckoned that the hierarchy of what matters on the bike in descending order is fit/comfort, power, aerodynamics.
However I’ve noticed that even when I’m JRA on flat roads, the post is bouncing up and down quite merrily. Maybe I just need to work on my pedalling technique but I started wondering on my last ride if this was costing me power and if so how much?
I guess that I’m losing leverage at my hips but I am not sure whether it is worth bothering about. I currently race Olys so if it was a big deal I could train on the Shok and then swap the post for races.
Any thoughts? Should I just work on technique? I could try a comparison on my trainer but I suspect that there would be placebo effect.
Kembo
I would suggest working on getting rid of the bounce in your butt. Maybe do some 10-minute “focus sessions” where you really get your feet going in circles. You can get rid of that bounce – everybody riding a Softride or Titanflex has to learn how. Once you get the bounce out, you can ride every bit as powerfully as on a solid post.
I have a hunch you are wasting a little power, since a shock-post doesn’t give back as much bounce as it takes (that’s why they’re called shock “absorbers”). You’re losing some power/energy to heat in the post.
Try to get rid of the bounce, and you’ll be fine.
Thanks Julian - I’m sure you’re right.
Time to do some more pedal drills…
