NB 101’s are notorious for being slippery in/on the wet stuff, the minimus is better due to a softer compound, and the new 110’s a mix of both previous models, is slightly better.
Good choice with the x-talon 212(?) as the compound and tread spikes work quite well on wet rocks, roots, but as someone mentioned, a very flexible thin-ish sole, (no rock-stop we agree on liking in the NB 101’s), so foot placement and lower center-of-gravity (bend your legs more, to absorb and mold each new foot placement to the terrain you are running over), and it’s all good.
Only drawback to the spikes and softer compound is wear, it’s quicker, especially if you have to run on harder surfaces (concrete/tarmac), to get to the trails where you finally get to enjoy being schooled by your four-legged friends.
Try the f-lite 230’s after you wear out your x-talon 212’s, I prefer them as no problem with wear issues on hard-pac, good proprioception feedback on the trails, gullies, ravines and coastlines, in and out of the water.
And if you still struggle to float and flow on the terrain you chose to go play on, take a cue from your dog, quick feet, light and dynamic, absorb some landings almost too a crouch, dance quickly and dynamically (pop-pop-pop!) on your feet over other obstacles, slipping and sliding is okay too, and the use of a third or fourth limb (your hands and arms),on bigger boulders in rivers and on the coast can even up the odds a little in your favor (one to two for us, against three to four limbs in use for them).
Have fun, you know our dogs are, every time, rain or shine!
I ordered the x-talon 190, can’t wait for it to arrive. There’s only 0.2mi pavement from my house to the trail, and I tend to be easy on tread (at least for road shoes), so I’m not too concerned about wear. If it is a problem, I’ll certainly check out the f-lite 230.
And thank you for all the tips!
