New R7000 group being installed on my bike. A nice new refresh of my beloved CAAD10. Im having some issues with the rear shifter. Mount it onto the bar and it clicks through its positions. Put a cable in and then it doesn’t do anything. I pull on the cable and it doesn’t do anything. I route it through the derailleur and it doesn’t do anything.
Do you still have the hood covers pulled up so you can wrap the bars? I have found this interferes with the shifter operation. Pull the hood covers down and try, you may need to do this and then pull them back up to wrap bars.
TT shifter or road bike brake/shifter? It it’s the TT shifter than chances are your cable is too long and when you shift the head of the cable sticks out. Before running it through the derailleur grab some pliers and pull on it (where it comes out of the frame by your derailleur) really tight and try to shift while you’re pulling on it, you should feel the cable move. If not, you may not have run the wiring correctly.
Pretty sure I did that. I think it can only thread through in one way. Not sure what I did differently, but I have gotten it to go through the gears now.
