Shimano GRX crank with 105 stages?
Anyone know if I can run a 105 stages with their gravel crank? I heard the grx have wider Q factor so wasn’t sure or would their mtb stages be better with it ?
Thanks
The arm will fit on the crank, but the sensor pod may or may not clear your chainstays. Will vary greatly from bike to bike.
Yep. But as above, it’s about frame clearance.
Shimano GRX Power w/ Road Single Side Power Crank: https://www.youtube.com/watch?v=y3XjBeE6ngA
I have lots of room with current praxis gxp crank not due if that matters
I just tried this. It didn’t work on my bike. I checked with competitive cyclist first. They said it would work, but literally just slight rub. So, they totally refunded me and I bought the 4iiii, since they were in stock but the color scheme is a little off grx 800 vs grx 600.
What bike?
Wilier Jena GRX-812 1x11
https://wilier.com/en/my2021/int/endurance-bikes/gravel-bikes/jena
Just to echo everyone else: it will work if your frame allows. I have a an Ultegra Stages on a GRX800 1x crank on my Norco Threshold. It works but the clearence is substantially tighter than it was previously.
