Hey all - sorry if this has already been discussed.
Does Shimano make a dura ace or ultegra hydraulic TT brake lever with out the Di2 shifters built in? I am running micro-shift cable shifters on the ends of my extensions and for the time being, plan to keep those in place, but will likely need to upgrade my levers in the near future.
Ok good to know. I guess at that point, would I even need to remove the electronics? Maybe just leave them in there and not use them? The Sram is also a good option. I’ll look into those. thank you! I’m currenting using the TRP levers you suggested, they are actually the reason for this post to begin with. They’re a bit too long for the new cockpit I have.
Oh electronic parts are modular and can be easily put back to original form so no need to worry about it.
I am also using s900 hrd and their square-ish fluid tank design makes me really secured when I am on a steep descent. I love them but they are relatively hard to bleed (compared to Shimano’s)
I also ditched my TRP levers and replaced them with Dura Ace Di2. I don’t see why you couldn’t just install them as-is and never connect the Di2 wire. The buttons don’t seem to be very intrusive.
