Shimano Di2 Etube no 11-32 option
Hi folks!
I want an eleven speed 11-32 cassette on my Shimano Ultegra Di2 set up for my QR PR-5. ETube does not have a 11-32 set up pre programmed. It only has 11-30. I have tried that setting and it seems to struggle shifting from the 14 - 16 cog. Anyone have a work around here or how to adjust it. I have tried realigning the derailleur and can’t quite get it to be very smooth.
Thanks in advance!!
Etube only uses the cassette info to inform you of your synchro shift gear ratios to decide where you want the FD to shift between big small rings.
The parallelogram on the RD determines shifting permanently for ranges of cassette sizes.
So etube has nothing to do with the shift issue.
Either adjust the RD or your RD hanger is bent. If di2 wont shift right at the RD it is either a max cassette size RD mismatch or a bent RD hanger.
