Hey ST, getting fast enough to be interested in shaving my legs. Tried it once 10 years ago and it went terrible - got like a bunch of red bumps / folliculitis.
Any tips on how to approach shaving down? Next race is in late May so figured i would shave now and figure it out
I use an electric razor, it’s pretty good! I shave all exposed hair including the arms
You might wanna go for the non-exposed as well
There’s no aero benefit but there are some chafing issues that could be remediated, especially when in conjunction with undercarriage lubricants, e.g., Squirrels Nut Butter
Thanks for any suggestions or pro tips!
Atrocious advice above.
Step 1: electric razor to take the length off
Step 2: go to town to shaving foam
Step 3: use a hand held razor with a brand new blade, being particularly careful over the shin bone, knee and behind the knee
Step 4: moisturise a lot
Step 5: race
solid advice above from PJH. and it’s not only about being fast, btw. do the full body shave, hit chest too. something i’ve not heard many mention, but with our inevitable multiple showers per day, waaay quicker to towel off with no body hair holding moisture. couple quick towel passes, done!
for fun, maybe look up sheep shearing competitions, those guys know how to manage time and make short work of it, watch
how fast they work. i’m sure you’ll figure out how to get reasonably quick at it. (yourself, not sheep) 6minutes or so, start to
finish. Good luck Yrocket!
Cut it back to a stubble with an electric trimmer first. Then shave with the most expensive lady’s razors (one per leg) you can find using Skintamates lady’s shaving gel.
As mentioned, use a trimmer first, then blade shave.
If razor bumps are an issue, rub some isopropyl alcohol on when you get out of the shower. Yes it stings (a lot), but only for about 10 sec. and does the trick.
Nair with Aloe & lanolin… don’t let the pink bottle scare you. If you’re wooly use a trimmer first.
With chemical depilatories like Nair, try it on a small section of your leg first…and not just before a race. They work great for some folks, but others either find that all the hair isn’t removed or that their skin reacts badly to the chemicals. If neither of these are the case it can be a good option.
I use a hair trimmer without a guard. Obviously not a super close shave, but no bumps or ingrown hairs to worry about.I do it that way for the first cutting.
Then I follow-up with a safety razor after/during a shower or bath. And maintain with the safety razor over time.
