What seams (location) are you referring to. Most shorts have a central seam down the middle of the shorts; it’s just that cycling shorts have such a thick pad it’s a non-issue.
I’ve had good luck with the Castelli Body Paint short (there is also a suit). Minimal seams, and a thick (by tri-standards) cycling pad.
It’s a seam running along the frontal plane (from L to R), not the one running from front to back. None of my cycling shorts have this seam, only the tri-suits.
Looking at my Body Paint shorts, no cross-seam (you can see how the leg seams are moved forward in the design). Checked my De Sotos and they do have one.
