I don’t see any point to run clinchers with tube and sealant. If you do it, go tubeless, don’t overcomplicate things.
I bet there are more than a few of us who don’t have TLR wheels and tires.
Right, and I think his point is that if you don’t, then don’t bother. You’re doubling the tube-caused part of the rolling resistance (for latex), and (more on this below) getting some fraction of the flat prevention odds of true tubeless. Albeit doubling latex rolling resistance is a pretty small hit.
Before road tubeless was ever a thing, I ran Stan’s in latex tubes for 4-5 years. Now after 5-6 years of having run true road tubeless, I can confidentally (but anecdotally) state that true tubeless flat mitigation is significantly superior to sealant-in-latex. Hand-wavingly, I think sealant-in-latex saved maybe 30% of flats. While true road tubeless saves something like 90%. I don’t know why. It just worked out that way. Also you go through expensive tubes pretty fast as the sealant dries. You can add more, but at some point it gets silly in terms of probable rolling resistance and weight hits.
Maybe Silca sealant changes those numbers. No idea.
I also run Veloflex Records and Corsa Speeds in non-tubeless form in certain cases where I don’t use those tires often enough to justify maintaining a full tubeless setup. E.g. race-only. Or in my case, having a few sets of the non-TLR Records that I can’t set up tubeless at all.
In my case for a super-duper A race where I’d want extra flat insurance, I’d just run Corsa Speeds (or the TLR Records) tubeless rather than run the Records with sealant-in-tubes. It seems counter-productive to buy crazy-low-RR tires, then add watt-per-tire sealant to the tubes.
If it’s someone without TLR wheels, I could see that little bit of flat protection being worth buying, though.
So far - knock on wood - I have yet to flat on tubed Veloflex Records except once on the track where I stupidly hadn’t checked the (very fast) wear, and wore all the way through the casing into the tube. I did not crash on the banking, thankfully.
