A word about tester’s choice and all that, and the scubadiving.com reference by cerveloguy… the backplate manufacturers don’t do a lot of advertising in Scubadiving mag… you won’t find many reviews of backplate systems for that reason.
I am sure the Aeris is a fine BC. But honestly, looking at it, looks like you are wearing a frigging comforter. just my opinion.
Don’t get hung up on Halcyon and they’re the only ones that “DIR” (do it right). They do it well, but they simply adopted cave diving techniques and equipment and translated them to recreational diving. Some of those ideas are genius, i.e., the bungee’d second, the longer primary hose. Some are just “rules” , i.e., no steel tanks and wetsuits, that don’t really apply to recreational diving.
Again, I’d recommend Deep Sea Supply for a local (So Cal) manufacturer. You can even call and get Tobin, the owner, on the phone. He helped me choose which wing to buy. As for warm water/cold water versatility, I have dived my steel backplate in everything from 45 degree water in a drysuit in British Columbia to 75 degree water in a 7 mil in Galapagos to 80 degree wter in a skin in Maui.
The primary benefits of the BP/W are that it puts you in a better position in the water and reduces your overall need for weight. Yes, you can get good buoyancy with a back inflate or a jacket, but think about where the weights are placed (around your hips) vs. the two primary repositories of air (the BC’s bladder and your lungs). You are automatically at a disadvantage since the weight is lower than the air, causing you to fight a heads up trim. Backplate puts 6# of weight right over those air sources, alloing for perfect horizontal trim (the most efficient position). Also, even with a back inflate, traditional BCs tend to “trap” air. A wing does not. When I went to a BPW I automatically dropped about 3 pounds of ballast. Add the 6# for the steel BP, that’s 9# off the weight belt/pouches out of the gate. Diving in California, that’s important. Add a steel tank and it’s even better. I think I mentioned, but with a steel tank and BP, I wear a 10# weight belt with a drysuit. That’s nothing.
With regards to weight, if you are diving California, wearing a 10# weight belt is safer (IMO) than a 30+# weight belt (or pouches, or harness) if you ever have to ditch, you won’t be a rocket to the surface.
Anyway, you are in SD? If you want I can find out some BP friendly shops to go look at them
