Scott Plasma 2 Sizing
Hi all, been looking at the stack/reach table here…
If I fit pretty good on a medium Specialized Transition (2009), am I correct in thinking a size small (52) Plasma should work well? Anyone out there tried both and can comment on sizing?
Thanks!!
Anyone?
I have a plasma Ltd 2010 size 52, fit me perfect. (I’m 5’10 and need a tall bike). Cervelo, Felt does not fit to me.
Used to have a Road Trek size 54 and a Road Look size M.
Not sure about Specialized.
good luck
Thanks, I’m 5’10 as well with somewhat stubby arms/torso. Do you run any spacers on top of the head tube?
I’m 5’10 as well, but I’m using a m. 100mm stem
same bike, plasma ltd 2010
2 spacers for better fit
Do you have a long inseam? Any idea off hand what your saddle height is? I typically have a saddle height of about 73.5cm (BB to top/center of saddle)…
Looks like the Small and Medium Plasma kind of sandwich the Specialized ‘M’ in terms of sizing…
I’m not sure. I have 32’ in mind, but I could be wrong.
You might wanna try the bike before buying it (go and see any retailer!)
The only bikes available for me to try are Cervelo and Argon. Anything else and I’d have to drive 10 hours…
Cervelo’s are a bit long for me. I briefly had a 51 P3C, but just could not get comfy on it, was using my forearms to support my weight.
I -was- able to get very comfy on the medium Specialized Transition, but disliked it for other reasons (brakes, slipping post, rear facing dropouts, and the fact that it weighed 23 pounds…)…
